supercharger with LT1 intake???
Old Feb 23, 2008 | 09:02 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Ok so I was thinking about switching from TPI to a LT1 intake. can you bolt a supercharger up to it? how are would it be? does anyone know if I modified it could a magnacharger be put on?
Old Feb 23, 2008 | 09:05 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: supercharger with LT1 intake???
just order one from a LT1 IIRC. a phone call to vortech or procharger would be your best bet.
Old Feb 23, 2008 | 09:08 PM
Axle/Gears: G92
what does IIRC mean? thank you. I will will them monday If I can. I really would like a would like a mangacharger or atleast that style.
Old Feb 24, 2008 | 12:23 PM
Pocket's Avatar
Car: 91 Trans Am
If I recall correctly
A LT1 intake is slightly lower and more frontward than a TPI
A slight modification of the plumbing is all you would need from a TPI S/C
Old Feb 24, 2008 | 12:26 PM
Axle/Gears: G92
thank you. what has to be done to the plumbing?
Old Feb 24, 2008 | 07:40 PM
Pocket's Avatar
Car: 91 Trans Am
Move it
I dont have a centri charger, only a TPI to LT1 swap
Old Feb 24, 2008 | 08:48 PM
Axle/Gears: G92
Move it
well duh. I should have relized that.
with a centri charger won't it sit right on the heads with its own intake manifold so technically I doesn't matter what intake just the bolt pattern etc.? I think. It am new to superchargers
Old Feb 25, 2008 | 01:18 AM
Pocket's Avatar
Car: 91 Trans Am
They are a remote setup, similar to adding another alternator
Intake makes not difference
Old Feb 25, 2008 | 09:13 PM
Grizzle B's Avatar
Car: 1984 Camaro Z28
Engine: '92 LT1
Transmission: 700R-4
Axle/Gears: 3.73 factory posi. disc brakes
more than likely just a new bend in the intake tube
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
