couple of questions before i plunge into it
Old Feb 27, 2008 | 11:57 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ALright i decided to go back on the nitrous plane. I saw this kit here because i can step it up to a 125 shot. Perfect for when i get my big build later down the road. http://store.summitracing.com/partde...5&autoview=sku
Well my question is that now i have an air filter that directly bolts on my TB. Can i put in that tb spacer for it and is that a proper distance for spraying my car? Timing should be what was it 2* for every 50? I forget its been a while since i sprayed.
Old Feb 28, 2008 | 01:29 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: couple of questions before i plunge into it
also that one doesnt come with a purge kit does it? If so will any other kit plug in as long as its same piping and all.
Old Feb 28, 2008 | 01:42 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
You may as well get the Nitrous Express kit (white bottle) that is made for out cars. It isn't too much more and it is actually made for TPI. It will be a lot more straight forward, and that is what I plan on doing down the road. I also think the 4th gen kits will work in our cars with little modifications.
Old Feb 28, 2008 | 12:23 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I have a HSR setup now.
Old Feb 28, 2008 | 04:57 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I am pretty sure they all go in after the throttle body. I have a super ram in mine. When I decide to get some nitrous, I am going to go with nitrous express. Also, I think their Hp rating are to the wheels, not at the crank like most other kits.
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
