sneak peek.....
Old Mar 22, 2008 | 05:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sneak peek.....
sneak peek of my twin turbo project....
Old Mar 22, 2008 | 05:32 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: sneak peek.....
That's gonna be awesome! It should spool up pretty quickly with 2 relatively smaller turbos than 1 big one right? You lookin to run on pump gas?
Old Mar 22, 2008 | 07:24 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: sneak peek.....
it should be more streetable than last years combo so that's what I was looking at. Spool time, I have no idea, but I'll just pick a converter accordingly so it won't be an issue.
Old Mar 22, 2008 | 07:37 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: sneak peek.....
Originally Posted by xpndbl3
Spool time, I have no idea, but I'll just pick a converter accordingly so it won't be an issue....
Why not go w/taller gears (lower numerically) out back, w/smaller primaries to help spool....?
Looks great so far!
Edit: Just realized your running exhaust log manifolds, any more pics....?
Old Mar 22, 2008 | 07:58 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: sneak peek.....
i will be swapping from 4.11 gears down to 3.50 gears in the 9" this season. Those are flipped over truck manifolds that I'll be using since the ebay headers came no where close to working for me.
Old Mar 23, 2008 | 11:13 AM
UR50SLO's Avatar
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Re: sneak peek.....
Those are Stock GN turbos... Right
I mocked this exact setup on a sbc sitting on a engine stand several years ago... You'll have to let me know how it does! I never had anything to put the engine I mocked it up on. It'll work good depending on how you fuel it/tune it.
The hard parts will do their job. I'll bet with the right tune it'll be very easy 10sec capible with excellent street manors. Internal WG's keep the cost and simplicty. Your on the right track in my openion!
Just knowing your not going to have any manifolds leaking ever is a great thing
!~Scott
Old Mar 23, 2008 | 11:56 AM
UR50SLO's Avatar
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Re: sneak peek.....
If you low-mount your alternator you can bolt both turbos up to the manifolds (or a small rise if needed to get off the V-cover) and then point both inlet's towards each other. The exaust sides would be pointing out.
The downpips would go down beside each exhaust mnflds. Both (press.side) outlets would point down and out toward headlights.. to FMIC.
3:50gear is perfect.
Just a thought on the Turbos.. that's how I had them mocked up on mine. Less tubing and the turbos will bolt right on to the manifolds. You'd need to check hood clearance.
~Scott
Old Mar 23, 2008 | 12:58 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: sneak peek.....
~Scott
The bolt pattern on the manifolds and the turbos are different spacing, so that would not work. The alternator probably won't need to be lowmounted, but the radiator will need to be moved forward towards the nose of the car 2" or so, or I will buy a radiator that is not as wide and run that instead. Hood clearance also wouldn't work bolting them that far forward onto the manifolds, I think I got it in a good spot, should have the basic piping done next week and post up some more pics once it's completed.
Old Apr 13, 2008 | 11:29 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
Re: sneak peek.....
whats the status wana see this thing some more
Old Apr 14, 2008 | 09:35 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: sneak peek.....
wrote out a really long status report then IE decided there was an "illegal operation" bs crap and I lost it all
so for the pic collectors at least:
Also got my new converter installed and SFI flexplate along with both turbos mounted and the downpipes ran to the end of the engine block for now. Also have the tank pulled and a -10 feed line added to the sump and I welded the -10 return to it while also welding shut all the factory lines on the pickup and return only leaving the float and vent line in place. Coming along nicely now, won't be long.
Old Apr 14, 2008 | 09:44 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: sneak peek.....
That's a sweet setup!!!
Old Apr 16, 2008 | 10:58 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: sneak peek.....
What induction setup will this new powerplant use? Blowthrough carb?
You coughing up camshaft specs this time, or is it voodoo black magic stuff again where us sweat hogs here wouldn't understand it ?
Old Apr 16, 2008 | 11:13 AM
xpndbl3's Avatar
Car: 1984 Z28
Re: sneak peek.....
nope voodoo magic, custom ground cam, call up a shop and blow $400 and you can have one too. no specs are given out, this is how the fast guys go faster. It is already stated that it is blow-thru carb. Should be fun to tune.
Old Apr 16, 2008 | 12:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: sneak peek.....
So even you don't know the specs? Huh. I figured it'd be weird, ie zero -> negative overlap for the turbo setup, but only Bullet or whoever you're using knows eh?
Sorry, looked up there and didn't see you mention the carb specifically. I figured so, but I had to ask. Customized by yourself or shop built for blowthrough? Tuning via wideband shouldn't be too bad, sneak up on the boost slowly eh? Wastegate springs, or a dial-a-boost type of thing?
Old Apr 21, 2008 | 12:10 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: sneak peek.....
Looking good!
Thats where I will place my twins also, when I'll start a TT build.
bluethunder28
Southern California Area
21
Sep 30, 2008 01:17 AM
xpndbl3
50
May 3, 2008 02:48 PM
greezemonkey
25
Mar 7, 2007 01:52 PM
thirdgen88
Dec 11, 2003 09:02 PM
CustomX
May 15, 2003 09:35 PM
