cheap power???
Old Apr 3, 2008 | 12:04 PM
maverickhatter's Avatar
cheap power???
does anyone know or recommend where I can obtain some cheap power the doesn't get as involved as a turbo or supercharger I have a 1989 trans am 305 TBI I just need something that makes it a little faster somewhere in between 50-100 hp together?
Old Apr 3, 2008 | 12:11 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: cheap power???
Nitrous my friend. You basically just answered the question of; What can I use nitrous on my car for?
Old Apr 3, 2008 | 12:15 PM
Re: cheap power???
but having to go more in depth to the engine for support to the seals like you should do with having nitrous and properly maintaining the structure of your engine, an in depth build for seals would cost just about as much as a small nitrous kit alone
Old Apr 3, 2008 | 12:18 PM
Car: 1992 RS 6spd
Re: cheap power???
Okay, then replace your heads with some stock vortecs and get a vortec TBI intake manifold. 30-40 instant always available ponies. I think lol.
Your heads on that TBI motor are what is mostly killing you, along with the 400cfm carb.
Last edited by calamitascamaro; Apr 3, 2008 at 12:19 PM. Reason: Automerged Doublepost
Old Apr 3, 2008 | 12:26 PM
cpaul76132's Avatar
Car: 1991 Chevy camaro z28
Engine: 5.7L 350
Re: cheap power???
Unfortunately, power doesn't come cheap. Personally, I'd rather build the motor to put out more power than go with nitrous. I've always seen nitrous as an easy way to blow up a motor. Start checking tech articles on this site or other f-body sites and see what others have done and what their results were.
Old Apr 3, 2008 | 02:48 PM
Car: 1992 RS 6spd
Re: cheap power???
Nitrous is like a razor in a candy bag if used the wrong way. Here's the thing though, it can also be used in a completely safe manner if you know a bit of info about your car, as in CR, CFM on the carb or TPI, or TBI, whether or not you can use an extra fuel atomization source to mix with the nitrous before entering the intake, and what octane fuel you run. Also if the setup has a WOT connection and a couple of other choice additions to the package then you can easily hit a 50-75 shot safely. Dry and Wet also has a lot to do with it........
Or you can go the bolt on route, find some headers, work your HEI a bit, advance your timing, open up your airfilter housing with an aftermarket, get some underdrive pullys, an a/c delete pulley for weight loss, a beefier cam, you might be getting close.
Last edited by calamitascamaro; Apr 3, 2008 at 02:52 PM. Reason: Automerged Doublepost
BRoss99
Aug 10, 2025 05:08 PM
evilstuie
Apr 14, 2016 08:52 PM
dutch930
Sep 11, 2015 06:58 AM
sailtexas186548
Aug 24, 2015 10:11 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
