nos wires!!! no clue need help!
Old May 7, 2008 | 08:37 AM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
i just got my nos in my camaro but cant figure out wiring. can some one help me?
Old May 7, 2008 | 09:39 AM
jsoll's Avatar
Car: 86 camaro
Engine: 406 sb
Axle/Gears: working on that
Re: nos wires!!! no clue need help!
pm sent
Old May 7, 2008 | 01:20 PM
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
you good or need more help?
Old May 7, 2008 | 02:59 PM
Engine: 355
still need help looking for graphic or something
Old May 7, 2008 | 03:57 PM
lt1z350's Avatar
When I get a chance later I will sit down and draw one up and scan it to my computer. Are you going with a full throttle switch or button on the shifter? Let me know so I know which to do
Old May 8, 2008 | 07:21 AM
Engine: 355
going to a button on shifter
Old May 8, 2008 | 07:57 AM
vwdave's Avatar
Either GM Hightech or Chevy High Performance recently did a article on this.
Old May 9, 2008 | 11:33 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
http://www.barrygrant.com/fromBarryG...3045_13065.pdf
i just used this to wire mine up...scroll towards the bottom, pretty pictures for ya...
i used diagram 4 because i used a relay
Old May 10, 2008 | 12:54 PM
lt1z350's Avatar
basically what I was going to do for you so that should do it. Sorry it took long to get back got tied up the other night.
Old May 15, 2008 | 05:27 PM
Engine: 355
what about going from a 12 volt wire with fuse to a toggle switch than to a momentery switch than to solenoids?
Old Jun 3, 2008 | 01:09 PM
Engine: 355
thanks for all the help nos is all wired up!!!
Old Jun 4, 2008 | 12:05 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
If you want to go fancy on your wiring set up you can do what I did.
https://www.thirdgen.org/forums/powe...-opinions.html
Old Jun 8, 2008 | 03:23 PM
Engine: 355
now thoes this fancy set up work good? have you made a pass with it?
Old Jun 8, 2008 | 07:16 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
No not yet. Hopefully in a couple weeks I can see what it will do.
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
apo_bailon15
Mar 28, 2016 05:20 AM
CORV3TT3
Aug 23, 2015 11:26 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
