Supercharging at 10:1 Compression? Safe?
Old May 13, 2008 | 09:13 PM
Adam Control's Avatar
What's up guys? Quick question...I have a brand new 383 with 10:1 compression and was wondering if it is safe to install a Paxton SN92 supercharger. This setup is only good for 6-8 psi of boost so I think it may be low enough to safely run with such high compression but I figured I'd ask you guys. What do you think?
Thanks!
AC
Old May 13, 2008 | 09:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Supercharging at 10:1 Compression? Safe?
i think you could get away with 6 lbs but need to tune it and possibly run a better camshaft designed for boost even tho your not running alot of boost. Just need something to bleed off some cylinder pressure
But i'm also interested in what ppl think about 10 to 1 compression and some lbs boost
Old May 13, 2008 | 09:32 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
If you use the correct pulleys to make boost later in the rpm band (peak boost above peak torque rpm) it should help to avoid excessively high cylinder pressures and detonation. Its really all in the tune, though.
Can an SN92 handle the 383? It might be good for 6-8 psi on a stock motor, but a 383 will probably take it way out of its efficiency range... meaning HOT air and more detonation problems.
Old May 14, 2008 | 06:24 AM
True. Honestly I never thought about that....
I don't really know of anyone in my arear that knows much about this. I wish I did this way they can help with a tune as well as some pulley recommendations. Right now the guy that built the motor says to stay away from the supercharger but a supercharger is just so tempting and it just so happens that I have one on hand.
FormulasOnly
Jul 23, 2018 08:47 AM
86IROC112
Nov 27, 2015 09:54 AM
roysatikas
Sep 22, 2015 08:15 PM
WhteRbt
Sep 21, 2015 09:48 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
