Fast response IAT sensor
Old May 14, 2008 | 11:22 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I'm looking for a quick responding IAT sensor and gauge to screw into my manifold. Anyone know where I could find one? The ones I've found are slow.
Old May 14, 2008 | 11:46 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Fast response IAT sensor
1990 V6 IAT.........fast responding. Use for boost applications. It is more fragile than the stock TPI IAT sensor.
Old May 14, 2008 | 11:54 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Interesting, is it a screw in type?
What gauge can I use with it?
Old May 14, 2008 | 12:02 PM
Guest
Guest
Posts: n/a
Its identical to the TPI IAT sensor, except the sensing element is in an open plastic cage instead of encased in brass. I believe its a 3/8" NPT? Dunno what you could use for a gauge.
Old May 14, 2008 | 12:24 PM
junkcltr's Avatar
Engine: 3xx ci tubo
The threads are 3/8" NPT...same as stock TPI IAT.
The electrical plug is different than the stock TPI IAT.
Use any gauge that will work with the stock TPI IAT, or just a voltmeter and lookup table.
Old May 14, 2008 | 12:46 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I like that idea. Once I figure out what my temps are, I'll add the alky injection, and then once I'm comfortable, I don't need the sensor or gauge anymore, so using a voltmeter would be a good cheap way.
About that lookup table......
92firebirdguy
Sep 1, 2016 07:53 AM
customblackbird
Oct 1, 2015 04:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
FormulasOnly
Sep 10, 2015 09:07 PM
rsrookie
Sep 5, 2015 07:08 PM
