Making the S-trim quieter
Old May 21, 2008 | 06:38 PM
winger67's Avatar
I have a Vortech on a 305 TPI. Very loud from day 1 at idle. I was thinking about upgrading to the V2-SQ but from what I've read hear it isn't much quieter than my current S-trim. I'm willing to trade power for stealth. Sure, I could remove it but what fun would that be? Since it's loudest at idle (700-800 RPM), has anyone tried changing out the pully to either larger or smaller to change RPM? I'm wondering if that would make any difference.
If I go smaller pully, I'd drop the rev limiter and consider adding alcohol injection. I don't race the car much any more but since he supercharger is already on it I'd like to keep it.
Old May 21, 2008 | 10:16 PM
whiteghost7's Avatar
Car: 92rs
Re: Making the S-trim quieter
The blower seems "loudest" at idle because your engine is quietest at idle. The faster a gear driven centri spins the more noise it makes, so no, the smaller blower pulley won't help quiet things.
What type of intake do you have on the blower? An airbox surrounding your filter will minimize the noise a bit, (not a whole hell of a lot) as will the use of a good lenght of sillicone or similar tubing to locate the air filter further from the impeller.
A gear driven centri whines, it's a matter of fact.
Old May 21, 2008 | 11:12 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
If your looking for a quiet blower look into Powerdyne. They use an internal belt instead of staight cut gears.
Old May 22, 2008 | 12:29 AM
winger67's Avatar
Taking the RPMs up to 1100 definitely quiets the Vortech. I realize there's not much more engine noise but with your ear under the hood you can tell it gets quieter. It's actually 900 RPM where it seems to be the loudest.
I'm running the Vortech supplied intake and filter. It's a couple of plastic 90 degreee elbows and dryer duct type hose to an oiled filter.
Maybe I'll look into selling the Vortech and going Powerdyne.
Old May 26, 2008 | 06:38 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Yep mines loudest at idle too. Its because it uses straight cut gears, like most stick cars use a straight cut gear for reverse. This is why you can hear the trans whine in reverse. Same thing. The SQ-trim uses a different gear tooth angle. Forget the name, helical? They are quieter, but still noticeable.
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
