Intercooler Causing Overheating, Solutions?
Old Jun 4, 2008 | 08:41 PM
1989irocz1's Avatar
Car: 1989 Camaro Iroc Z28
Axle/Gears: Borg Warner 9-Bolt/ 2.77
The other day I was mounting up my intercooler to test the fitment. I decided to leave the intercooler mounted up to see how engine temperature was when I drove around. Engine temperature stayed between 160 and 220. Which is a lot higher than it is without the intercooler. I have a manual fan swith that I never used until now. How can I fix this heating problem? How can I make it so the radiator gets more cooler air? Do you guys with intercoolers have engine heat problems then? I just bought a new radiator less than a year ago with out any heating issues until now.
Old Jun 4, 2008 | 09:34 PM
Guest
Guest
Posts: n/a
Re: Intercooler Causing Overheating, Solutions?
Pictures?
Sounds like you're blocking too much radiator airflow if you think between 160 and 220 is a problem. Need to find a way to get more air to/through the radiator.
Old Jun 4, 2008 | 10:02 PM
1989irocz1's Avatar
Old Jun 4, 2008 | 10:09 PM
1989irocz1's Avatar
I removed the fog lights to let more air through. I was thinking of using some some flex tubing to force more air to the radiator somehow.
Old Jun 4, 2008 | 10:20 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
What thermostat are you running?
Guest
Guest
Posts: n/a
Could help.
What temp does the fan come on? Because if it gets up to 220 then cools off... its fine. Its when you cant get the temp back down.
Old Jun 4, 2008 | 10:34 PM
1989irocz1's Avatar
It was a 90 degree day yesterday and it went up to 220 briefly when i was cruising at 25 mph. The fans kick in automatically around 160-190 degrees. I am not sure about the thermostat. Whatever is in there, it is stock. Normally my car temp would be at 100-130 degrees when I drive around even during the summer months last year. Then now it sits at 160-180 when I drive normally.
Old Jun 5, 2008 | 01:40 AM
Pocket's Avatar
Car: 91 Trans Am
Stock thermo is 195
I dont see how you were cooling that low pre-IC
I suspect a faulty gauge
Old Jun 5, 2008 | 10:40 AM
1989irocz1's Avatar
Originally Posted by Pocket
Stock thermo is 195
I'll have to take a picture of the gauge with and without the intercooler.
Old Jun 5, 2008 | 10:56 AM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Did you leave a gap between the IC and the airdam? I left an inch on mine and its working fine. Getting air to the radiator via the airdamn is critical on our cars.
Old Jun 5, 2008 | 11:15 AM
1989irocz1's Avatar
I think that could be the problem with me. I just checked and the intercooler is about 1/4 inch away from the air dam.
Old Jun 5, 2008 | 11:23 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I don't see any problems with your car. A 195 stat will make the car run upwards of 220.
Old Jun 6, 2008 | 09:45 PM
1989irocz1's Avatar
I fixed the problem. I made the gap between the air dam and the intercooler to more than an inch. The larger gap helped, so thanks for the help.
Old Jun 8, 2008 | 04:15 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Well if it ever bothers you again, get an aftermarket temp gauge, and a 160* stat. Maybe an aluminum rad.
Your car warmed up a lot higher than 130*...unless you run methanol as a fuel.
Old Jun 8, 2008 | 06:44 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
I have the exact same intercooler, and in the exact same place...lol... I have a new aluminum rad that is narrower but about three times thicker then factory and I don't have any problems keeping it cool.
Old Jun 9, 2008 | 08:54 AM
lock's Avatar
Car: 86 IROC-Z
Good to hear that fixed it!
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
