started my nitrous setup
Old Jun 8, 2008 | 09:30 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
bottle painted and mounted, blow down tube made.
got the fuel cell fitted. fabbed up some brackets out of some tubing i had. flat stock i had used before looked horrible. i would have liked to use a lil smaller tubing, this was lying around.
Old Jun 8, 2008 | 09:36 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
Re: started my nitrous setup
Looks like a start to a clean install. Does the homemade blow down tube pass NHRA tech?? also what up with the gold over spray , lol.
Old Jun 8, 2008 | 09:59 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
as long as it exits the car. i had a similar setup before. there is no pressure build up in the line since its an exit tube. as long as its not a rubber line, i think you are ok.
where is the gold overspray?
Old Jun 15, 2008 | 04:05 AM
89TXIroc's Avatar
Car: 89 IROC 5.7
Engine: 357
Originally Posted by stage20
Behold, Clean setup overspray!!! lol keep us updated
Old Jun 15, 2008 | 11:56 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Nice set up. As for the blow down tube. That should pass tech. Its not like its pressureized. Just needs to vent out of the car.
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
