Blow through carb differences - just curious...
Old Jun 29, 2008 | 10:52 AM
bigbird89's Avatar
Car: 86 Firebird
I'm like half a lifetime away from ACTUALLY installing a supercharger on my 86 bird, but I have a general question I thought some of you guys could answer (I did search, by the way).
I'm probably going to replace/ rebuild my e4me q-jet soon, and I was wondering what would be the best choice if I were going to supercharge and run a blow-through system in the future.
What mods are necessary to make a carb work in a blow-through app.? Also, is there a certain carb that will/won't work well? I was leaning toward the 1406 Edelbrock simply because it's so...well...simple.
Any input is appreciated!
Old Jun 29, 2008 | 12:01 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
Re: Blow through carb differences - just curious...
i bought mine from csu and it was well worth it. 1000 bucks for 850 for e85 fuel. less for gas. and less if you only need a 750. i believe the 750 is good to 1100 hp.
Old Jun 29, 2008 | 06:07 PM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
this is a good question. I too was wanting to ask this, as I am wanting to modify a 4776 600 double pumper for this.
So the question is "how would one go about modifying a carb for blow-thu?"
Old Jun 29, 2008 | 07:09 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
my suggestion wouldb e to just buy one. if you can afford a turbo setup and a good lower end. i would not take the chance then their are others that konw exacly how to do it.
im not saying that you or i could not do it. but its a lot easier when someone that specializes in this field does it.
you wouldent let a plumber run all your electric in your house.
andi i know i cant afford to blow up a 10,000 engine becuase i forgot to do one thing on a carb that i converted.
Old Jun 29, 2008 | 07:19 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
how to convert a carb to blow through... specifically the Holley DP http://www.hangar18fabrication.com/blowthru.html
Old Jun 29, 2008 | 10:04 PM
bigbird89's Avatar
Car: 86 Firebird
That's great information, now I know it can be done. How about an edelbrock?
Old Jun 30, 2008 | 05:40 AM
84bandit's Avatar
go on the carb section of theturboforums.com, there is about a 5 or 6 page thread about modifiying a edelbrock/afb carb for blowthru
Old Jun 30, 2008 | 01:14 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
you can buy a barry grant blow through mighty demon carb for about 500 bucks. Has been working well for me. Smooth and appears to be a good fuel curve so far.
I modified a holley two years ago, and it worked OK. Took a lot of tuning to get the low speed right, and the idle not pig rich. Had to drill holes in the butterflies. Peices of wire in the IFR's. PITA.
Its easier to start with a highly adjustable carb. Unless you drill and tap to make adjustments more feasable.
Old Jun 30, 2008 | 08:13 PM
Kendol's Avatar
I agree with the prebuilt approach. I bought a Carb Shop 750CFM carb initially for my build, did my dyno runs with it, and it worked flawlessly. All I had to do was adjust the idle screws. Carb was great right out of the box and cost a little over $850. I now use the Hogan's/FAST EFI, but the CSU carb worked great given its cost and performance.
Seems like given the added insurance and adjustability the CSU carb gives, this would be a no brainer for those wanting a low cost approach to fuel control in a boosted application.
Old Jun 30, 2008 | 08:18 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i put together my own blow thru carb with my proform 750, took a few hours, nothing major to do it either.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
