anti lag system FTW
Old Jul 13, 2008 | 12:12 PM
project89's Avatar
anti lag system FTW
woot i finished up modifying my megasquirt for the true antilag system and i effin love it, 2-3 seconds to build 20 psi of boost
can i use the antilag system threw a muffler? ive only tried it with my open downpipe. and the thing shoots about a 2 ft flame out of it not to mention bangs and pops insanley loud.any risk of blowing up the muffler case?
and what would u guys think a safe max turbine temp would be,im going to install an egt probe right before the turbo inlet to monitor the temps to make sure i dont get things to hot
Old Jul 13, 2008 | 06:32 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: anti lag system FTW
obviously unburnt fuel collecting in the muffler wouldn't be a good idea when it finally lights off.
Old Jul 13, 2008 | 08:26 PM
project89's Avatar
im aware of that but with the muffler being at the end of the ex system i dont think it would coolect any unburnt fuel,since it pretty much all gets burnt pre turbine.but i can see the system maybe building presure up inside the ex system
Old Jul 14, 2008 | 04:10 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Sounds like a typical timing retard and rich fuel to spool it. Did you try turning off the antilag and see how it spools? Maybe you don't need that much fuel and timing reduction. Keep in mind that beats on the exhaust valves.
What size turbine is on that to need the antilag ECM option enabled?
Old Jul 14, 2008 | 04:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I was just going to ask, what is "antilag" option? Is it only for the first split second of throttle actuation ?
If it is just rich fuel and retarded timing, it will blow your muffler apart. That's a time tested fact - we call it muffler explosions in our industry, and it's extremely dangerous.
1) Run it with no piping at all (current)
2) explore without the anti-lag option.
project89's Avatar
its got a small turbine on it right now, ptrim wheel with a t3 .63 housing, im planing ahead for the larger 1.x housing on the 74mm turbo.
on the foot brake i can only get 9psi without the antilag before the brakes wont hold, i can set the antilag so far below my 4k converter that this thing would build boost as high as i have the wastegate,deff gonna make for some fun launches.
and yes im using -10* of ignition timing + an additional 25% fuel
tell ya one thing it makes for one great fire and sound show
i do knwo alot of the import guys run them with mufflers but there running them dam stright threw mufflers,prettu much the same thing as one of those red cherry bombs, im looking to bolt an adjustable borla catback on the car
Old Jul 14, 2008 | 04:40 PM
project89's Avatar
sinc emine is an automatic car i have it hooked to a momentary push button,how it works is u pre stage the car, and press the button and lean into the throttle. at a set tps setting it activates.the first action is 2 rpm limits
my soft limit is set at 2,800 rpms, and the hardlimit is set to 3,300
when the motor is brought upto 2,800 rpms it starts to add extra fuel and retard the timing.
it will continue to do this till 3,300 rpms at which point it acts like a full out revlimit and starts droping sparks.
during this time i will have rolle dinto the stage beams,light goes green u let go of the brake and antilag button and ur off.
on a stick shift car instead of a push button u could wire it to the clutch switch, though an arming switch so u could deactivate it.but everytime u changed gears u could have the antilag system activate and keep the turbo spooled between shifts
very useful in drag applications, but very hard on turbos and ex valves/headers.
Old Jul 14, 2008 | 04:46 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
sounds like ur talkin bout a two step, stutter box etc....
I have a MS which one do you have and how do you have it set up in megatune?
Old Jul 14, 2008 | 04:47 PM
project89's Avatar
yeah its a 2 step + timming retard + added fuel, i have a ms1 runing msnextra code lemme take some screen shots of the config and ill post them
Old Jul 14, 2008 | 04:57 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
ahh i have an MS II. I think i i figured out how to program a "software" two step in Megatune using an input from one of the unused pins on my clutch switch.
i'd love to get more info on this tho...
Old Jul 14, 2008 | 05:03 PM
project89's Avatar
ms 2 has extra code now dosent it?
full sized pic here
http://i76.photobucket.com/albums/j3...ify/launch.jpg
opps forgot to ad dim using the nitrous tables to inject the added fuel, but thers many ways to do it
Old Jul 14, 2008 | 06:30 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
I cant find anything close....
also on a side note when ever i try to load a file set up for MS II code megatune gives me an error and asks if i wanna kill the program, if i do it closes if i say no it opens mega tune but megatune runs slow
Old Jul 14, 2008 | 07:00 PM
project89's Avatar
ive never looked at the ms2 stuff but ill go take a look and maybe i can find it for ya
Old Jul 14, 2008 | 08:22 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
... Click Here, and Here
Old Jul 14, 2008 | 09:23 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Thanks dude... !
vwdave's Avatar
Wouldnt a trans-brake and a 2-step give you the same results and alot less abuse?
Old Jul 14, 2008 | 09:27 PM
project89's Avatar
well i dont have a transbrake as an option unfortunatley, but yes they could give the same results but, with an antilag system u could run a massive hotside. put it this way with a transbrake and 2 step with a 4k converter id be hard pressed to spool up a turbo with a t4 .1.32 housing with only 173 ci, but with an antilag system that thing woudl spool right up to full boost on the line.
the major advantage is being able to run a huge hotside housing and wheel so u dont choke the motor in the high rpm ranges
Old Jul 14, 2008 | 09:30 PM
mesterz2889's Avatar
i was wondering what caused that now i know
Old Jul 14, 2008 | 09:37 PM
project89's Avatar
heres a good link 2 http://www.youtube.com/watch?v=gOnYA...eature=related
Old Jul 25, 2008 | 04:44 PM
project89's Avatar
i found the setings for u man
goto basic settings on megatune,and click on the bottom of the menu were it says basic/advanced user then selecte advanced and u will unlock the launch control and many other features,sorry it took so long ive been dam busy
btw this will open up settings for thingslike traction control nitrous control boost control the antilag etc
Old Jul 25, 2008 | 05:34 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
i found it under the general tab.... for what ever reason my Megatune looks different than urs...
I activated MSnS extra in the configurator and then set my cars profile code to MSns_Extra and started megatune... mine looks like this.
this is confusing... Also will running the extra code on my MS scrap it or not? i dont wanna fubar my MS with bad firmware
note the top menu bar is diff than yours
Last edited by Saigon_Bob; Jul 25, 2008 at 05:35 PM. Reason: Automerged Doublepost
Old Jul 25, 2008 | 05:56 PM
project89's Avatar
what version of megatune is that, im still using 2.25_p4
u dont need msnextra thats for ms1 cpus, the base ms-2 code has all the features
nm i see u have an older verison
open the configurator and setup a test car with ms-2 code and then do what i posted above to unlock the features
Old Jul 25, 2008 | 06:15 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
where can i find the newer megatune program...
when i load the car with the MSII code megatune gets all stupid and runs slow and shitty...
I've yet to test this on the actual car im just trying to get comfy with this b4 i do it
Old Jul 25, 2008 | 06:18 PM
project89's Avatar
im sorry i was wrong i thought i had 2.25_p4 i do onfact have P3 i would backup ur vew files and try to reinstall are u running vista by anychance?
http://www.megamanual.com/files/soft...25p3_setup.exe
u could always try megatunix, which is the unix/linux tunning software but its been ported to windows though on my old *** laptop it ran slower then megatune
Old Jul 25, 2008 | 06:38 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
i downloaded megatune through diyautotune and it looks like urs and came with the MSII extra code
yea i have vista
Old Jul 25, 2008 | 06:40 PM
project89's Avatar
there my be issues with megatune and vista,next time u run megatune right click on the megatune shortcut and click run under xp mode or whatever it says and see if that helps
Old Jul 26, 2008 | 07:55 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Hmmm with the D/L i got from DIYautoTune my megatune looks like urs and runs better :dunno:
time to start researching even more. haha cuz the new megatune i got has the MSII extra code and it says something about using a daughterboard and whatnot....
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Stryker412
Sep 20, 2015 06:59 PM
dimented24x7
Sep 6, 2015 03:51 PM
