E85 and nitrous
Old Jul 30, 2008 | 03:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
E85 and nitrous
Unless the search function is letting me down, there isn't much information about this topic.
My interest comes from an upcoming "need for speed", namely Pinks All Out. They have a 12.99 max ET requirement the event; at our 5800' altitude, I come up a bit short - 13.3's typical. So, I need to add a little to get more toward the sea level performance the car is capable of. Nitrous makes the most sense.
I've been looking into this since last winter, and haven't had much success. There are a couple of outfits that have done work with nitrous and E85, such as Nitrous Systems and Nitrous Express, but their websites don't have much information on how to do it yourself. There were some weight/time/power level flow values, but that was about it. And, their E85 systems tend to be pricey and/or overkill.
Talking to a fellow racer earlier in the season, he said he had an Edelbrock Performer kit that he bought with the intention of modifying for E85 use, but ended up stroking the engine instead. So, he sold me the still-bubble-wrapped kit for about 2/3rds of its going price. It's a 50-75-100 kit, but even the 50 should get me under 12.99, 75 would mostly compensate for the altitude, 100 would guarantee it even on a hot day.
I called Edelbrock's tech line to find out if they had done anything with nitrous and E85, as I had heard they had done carb work with E85. Well, about all they could tell me is their materials were compatible with E85, including the solenoids. So, not much help there.
The typical stoich flow ratio E85:gasoline is 1.47. Meaning you'd need 147% of the flow area of gasoline to equal the fuel flow required for E85. I corresponded with Mike Trittle, who contributed to the E85 thread on the Carburetor forum, he confirmed that for the people he knows that have run E85 and nitrous. The Edelbrock kit has 46-53-65 jets (which stand for .046", .053", and .065") for the 50-75-100 shots, respectively, assuming 5.5 psi fuel pressure. Doing the flow area math, the 65 jet would work with the 75 shot, but the 100 shot would require a .079" jet. Neither Jegs nor Summit could get me a jet that size on time, so I checked locally - all I could come up with were .078" and .080". So, I guess I'll either use the .078" at my current fuel pressure setting of 7 psi, or use the .080" and drop fuel pressure to 5.5-6 psi.
I have yet to turn a wrench to install the system, hope to start that process tonight. I added a purge solenoid to the parts obtained, not sure how necessary it is but was recommended by another fellow Pinks AO entrant who needed to pick his car up (he's running gasoline). I run a 2-step and have been flooring it upon staging, so I'll need another relay to open the circuit when the brake is on - or change my staging/launch so I don't engage the nitrous until I leave (in other words, don't floor it until I leave). I won't have a lot of testing opportunities (PAO testing is Aug 8), so hopefully this small of a shot won't lead to problems.
For the record, this is for the 396, which was put together with forged pistons (~10:1 static CR) and somewhat loose ring gap (.028" if memory serves - it was 11 years ago). I have an MSD Digital 6, so can also do spark retard if necessary. I did consider converting back to gasoline for this one event, but the only gasoline carb I have right now is a standard Holley 4779 that needs completely going through. I'm not too worried about the car handling it, as it's only going to go about as fast as it did at sea level.
Old Jul 31, 2008 | 05:56 PM
five7kid's Avatar
Got started installing it last night. Looking at the plate, man, those holes are tiny. Thought I'd better double-check the flow capacity of the plate, Edelbrock tech said it's good to 125 horse on gasoline, so it should be okay for E85. But, now I'm wondering if it's marginal.
Might stick with the 75 shot to be safe.
Old Jul 31, 2008 | 06:12 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: E85 and nitrous
Keep in mind that flow is a function of hole area, not hole diameter. Area is a squaring function.
With that, I wouldn't go over a 100 HP shot unless the holes were measured and calculated to HP for E85.
EDIT: To increase the fuel flow by 150% (1.5) then the diameter needs to change by 1.25.
125HP / 1.25 = 100 HP max. for E85 with that plate.
Old Jul 31, 2008 | 07:38 PM
five7kid's Avatar
Understood about flow area vs. flow diameter. 1.47 x .065" = .0955".
Might try 75 shot if test time permits. If it produces the desired results, might stick with it. But, if you can do a 100 shot. . .
Old Jul 31, 2008 | 08:03 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: E85 and nitrous
Is a 75 shot with e85 more than 75hp?
Old Jul 31, 2008 | 08:12 PM
five7kid's Avatar
You're adding the same amount of extra oxygen. You need to add the same ratio more E85 vs. gasoline as you do NA. Theoretically, it would produce the same power difference as it would doing a 75 shot with gasoline.
But, octane differences, CR, VE, NA HP, all those old variables, come into play. Since my CR is relatively low for E85, I may not have to retard the timing with N2O + E85 like I would for N2O + gasoline (I run the same advance at sea level as I do at altitude, for what that's worth). So, the power gain might be slightly more, since I would probably have to retard the timing with gasoline & the shot.
Old Jul 31, 2008 | 08:27 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Re: E85 and nitrous
I was thinking more along the lines of the BTU difference. If I figured it out correctly e85 should give you 4 or 5% more BTUs in the cylinder. Not much extra power at that hp level though.....
How come you arent running more compression?
Old Jul 31, 2008 | 10:15 PM
five7kid's Avatar
I built the engine in 1997. I converted the fuel system only (basically the carb) to E85 in 2006.
If built for E85, it would have more compression. I ran gasoline briefly the beginning of the 2007 season (long story) - it was slower than on E85. Probably tuning issues. But, I've never firmly established the power difference with only the change in fuel and associated tuning.
From everything I've heard, you need to raise compression to get the power possible out of E85, at which point it will put out slightly more power than the same engine on gasoline.
Old Aug 4, 2008 | 05:07 PM
five7kid's Avatar
I was hoping to get far enough along to get some weekend tests in, but didn't make it. A lot of details, I think I'm getting close, though.
I finished the plumbing, got the bottle filled, and went to check for leaks - there was a big one at the bottle adapter. Apparently Edelbrock didn't put a thick enough Teflon gasket in the kit, as the bottle fitting nut wasn't threaded all the way to the bottom, and the threads bottomed out before the Teflon washer was getting compressed. I took those two pieces to a local speed shop, all they had on hand were Edelbrock adapters, and he said they all looked the same. He did have a thicker NOS brand Teflon washer, so hopefully that will cure the problem.
The Edelbrock purge valve came with an in-line adapter that had sheared-off threads in the female end - not sure what that was about, but after digging the thread piece out, it fit fine.
If the thick washer takes care of that leak, and there aren't any others, all that's left is the wiring. I think I have everything lined up for that.
Old Aug 4, 2008 | 07:15 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Re: E85 and nitrous
Geez, sounds like simple important stuff you think Edelbrock wouldnt want to miss.
Old Aug 4, 2008 | 07:25 PM
five7kid's Avatar
They are going to be getting an email, of that you can be sure. . .
Old Aug 5, 2008 | 01:49 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
Re: how to run E85
i run e85 an i love it.
the quick fuel kit is for 4150 dp carbs.
it does not include new jets, new airbleads, and new boosters or squirters
i would suggets buying a whole new carb for e85. they are more but you get a high flow mainbody, billet baseplate and better bowls.
my e85 carb is tuned for a blowthrough turbo applicatoin. but i tried it on my s10 anyway.
drained all fuel out of system, added in new e85 bolted on carb. and ran.
within 3 passes i matched my et and mph on 114 race gas, on spray i was faster on a 175 shot than i had went before on 225. \
to buy 114 arround here now is anywhere from 8 -12: a gallon
and e85 has went down to 3.20 - 3.30
i have had no corison issues, and no problems with leaving it in between races. i love the stuff.
buy running it instead of 114 im saving about 60-80 a weekend on race gas
and the truck et dosent slow down due to temp outside. unless the track sucks. but the motor mph realy never slows
Old Aug 6, 2008 | 01:44 PM
five7kid's Avatar
I copied mattsv8_03's post from the Carburetor forum here, as his experience was more power with E85 than with gasoline shot-for-shot. I communicated that to Mike, he attributed it to the slower burning rate.
I finished the install last night and verified the circuits w/o fuel or nitrous turned on. Hope to finish the check-out this afternoon and get to the track for test & tune, weather permitting.
I'm sure I won't have time/resources to optimize this, if it makes it quick enough and doesn't hurt anything, I'll be happy.
Old Aug 6, 2008 | 11:52 PM
five7kid's Avatar
T&T tonight, a police/patrol sponsored "take it to the track night". Lots of front wheel drive cars, everybody runs in the groove. Weather forecast not promising.
DA 8700', 10-15 MPH head wind.
NA:
1.89 60' (worse than usual), 13.410 @ 99.7 MPH (about a 10 MPH head wind).
1st nitrous pass, 57 nitrous/80 fuel jets, 4 degrees retard in the box:
1.68 60', 12.019 @110.6 MPH (about a 15 MPH head wind).
Best nitrous pass, same jets, no retard in the box:
1.66 60', 11.996 @ 111.0 MPH (about a 10 MPH cross head wind).
A couple of nice things:
RT's still in the "reasonable" range; ran two 11.996's back-to-back; all MPH 110 or better; worst nitrous pass 12.06 with a low bottle and 78 fuel jet (probably shouldn't have run it that way); rain held off until after the last pass of the night.
It seemed to like the 80 fuel jet and no retard best. Probably means I need more advance NA (but my CR is pretty low).
My goal was to get comfortably under the 12.99 requirement for PINKS All Out, more like what it runs at sea level - I think I over-achieved a little.
But, that's fine. . .
Old Aug 10, 2008 | 01:28 AM
five7kid's Avatar
If you are interested in that kind of stuff, watch the Speed Channel October 9th.
The track was filling so many nitrous bottles during test & tune Friday for PAO, their tank ran out and they had to have more delivered.
I'd tell you more, but this isn't the Racing forum. . .
Old Mar 4, 2010 | 09:26 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Re: E85 and nitrous
I am revivng an old thread, but I figure why start a new one.
I am going to run nitrous with E85 and had some questions. I have found through online research that increasing the fuel jet 30% should be about right. My biggest question arises from the gas size jet to increase. I am using a NOS Cheater kit, and from what I undrstand it will run terribly rich with the reccomended jetting. Some say that for a gas kit to start with square jetting. If I went by this then I would use a 53 nitrous jet, and then increase the square jet by 30%. Which would be a 69 fuel jet for E85. Does this sound right, I notice that it is a lot leaner than five7kid was using.
While I am on the subject, can anyone tell me a basic formula for fuel pressure increase and how it relates to nitrous fuel jetting? I will be running one large fuel system, so it will be at 7psi vs. a more typical 5 or 6. How much should I decrease my jet size for a starting point?
This is my first time with nitrous, as well as my first with e85, so any advice is appreciated.
Old Mar 4, 2010 | 11:16 PM
five7kid's Avatar
Wow, forgot about this thread.
You need to use the fuel pressure for which your system was calibrated. There is no reason to raise it to 7 psi if the nitrous system is set up for 6 psi. If you do fuss with those things, you'd better have air/fuel monitoring so you know what it's doing.
I ran a reduced shot for the 2009 season just to get under the minimum ET required for a class I wanted to run at the local track (finished 6th in season points, even though I missed a race). I dropped the shot from 100 to 50, and the calculated fuel orifice worked out well (as far as I can tell - didn't hurt anything, anyway). This season I'm adding an air/fuel meter, so I should be able to keep better tabs on it (doing it mostly for NA, but it will be good to know when spraying as well).
Old Mar 9, 2010 | 10:01 PM
bart91406's Avatar
Car: 91 rs
Transmission: th350
Re: E85 and nitrous
The nitrous system is not designed for a specific fuel pressure. The kit manufacturer gives the reccomended jetting based on a specific fuel pressure, and then the fuel pressure can be used as a tuning aid to fine tune the kit. The question I have is how much 1psi of fuel pressure affects jetting. Is 1 psi equal to changing 2 jet sizes?
Has anyone else used E85 with nitrous?
Old Mar 30, 2010 | 05:32 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: E85 and nitrous
here's a little more info, i'm planning on running e85 in my car
http://www.e85performance.net/forums...splay.php?f=11
Old Mar 30, 2010 | 07:51 PM
five7kid's Avatar
Re: E85 and nitrous
http://www.e85performance.net/forums...read.php?t=581
Old Mar 31, 2010 | 03:04 PM
Ronny's Avatar
Re: E85 and nitrous
I would think a WB would be usefull in tuning N20.
Old Apr 2, 2010 | 09:55 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Re: E85 and nitrous
nope, only way to do it is reading the plugs...........wideband can't be trusted on the juice. there's too much more going on in the cylinder than JUST air/fuel
Old Apr 2, 2010 | 11:01 AM
five7kid's Avatar
Can't read plugs with E85.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
overdriv
Aug 20, 2015 03:52 PM
FlyinLow89
Nov 12, 2001 02:35 AM
