Fuel flooding the intake???
Car: 91 Camaro TBI 5.0
He guys, I have a 1991 3.1l , Im in the middle of a turbo project and something very strange happened, the car yesterday wouldn't start and when I removed the intake and looked into the throttle body, fuel came almost pouring out. I do have an external fuel pump to increase fuel pressure, did I somehow flood the entire upper plentum to have fuel comming out of the throttle body? How did that happen? And what broke?
Re: Fuel flooding the intake???
It's a standard t3, however I dont believe the problem is the turbo, the turbo itself doesn't have anything to do with the fuel delivery as far as I know, something is happening in the manifold, it's like the injectors are continuously firing completly filling the entire pletum.
Car: 1981 Chevy Malibu
Engine: 355 tpi
Transmission: t400
Axle/Gears: 12 bolt 3.08
I,ve seen a tbi injector short out, stuck open. In my case the the driver in the computer then failed. Had to replace injectors & computer. Remember also tbi injectors run on fairly low pressure. If your extra pump is compounding the pressure of the stock pump it may be possible to force fuel past the pintle of the injector. HTH Mark
Car: check
Engine: check
Transmission: check
If the charcoal cannister fill swith fuel it will then dump raw fuel into the plenum. Although this is usually caused by switching the hoses around at the tank. Pull hose from cannistoer at TB, and see if fuel pours out.
RBob.
his turbo is not to big he has the same turbo i am running, it sounds liek the injectors are grounded making them stick wide open.
or as rbob said the fpr or charcol can
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
