vacuum advance distributer?
Old Oct 15, 2008 | 11:48 PM
pyrofire127's Avatar
i will be running a TT set up on my 350 sbc and it will be carb with a 6AL
Can i buy a distributer with a vacuum advance or will that mess up under boost???
And would it keep advancing in boost?? because id really prefer if it would retard after 0 vac haha
Old Oct 15, 2008 | 11:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: vacuum advance distributer?
A normal vacuum advance cannister won't keep retarding under boost. Once you're at 0 degrees, that's it. Years ago there were cans on the market that would, but I don't know if there still are. You could use an electronic boost retard box, though.
Old Oct 22, 2008 | 07:36 PM
whiteghost7's Avatar
Car: 92rs
is it necessary to run a check valve to prevent the canister from seeing boost?
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
Jorlain
Oct 8, 2015 01:57 AM
drptop70ss
Oct 4, 2015 09:44 PM
camarohelp
Sep 12, 2015 05:45 PM
