is a supercharger carb necessary???
Old Oct 26, 2008 | 04:46 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
hey guys im goin to be putting a weiand 142 roots style supercharger on my camaro over the winter and i need to know if a supercharger carburetor is necessary only because i just picked up a quick fuel 750 carb that does not have any vacuum ports on the carb at all.and i would like to continue to use this carburetor........it is a drag race setup carb. any help is appreciated thanks
Old Oct 27, 2008 | 09:40 PM
Re: is a supercharger carb necessary???
anyone?
Old Oct 27, 2008 | 11:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need to reference the power valve to manifold pressure. I don't know what else you need to do, though.
Let's try the Power Adder forum instead of the Carburetor forum.
Old Oct 27, 2008 | 11:28 PM
thanks for moving it for me five7kid.......... i thought since it was a carb question i would put it in the carburetor section.
on another note i have heard of a power valve block off plug... im just concerned i wont be able to use the nice carb i have sittin on my 355
Old Oct 28, 2008 | 01:00 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Use your current N2O fuel solenoid for the boost fuel. Turn the solenoid on with a Hobbs switch. Do the power valve mod. so you don't blow it out.
Boost reference your fuel pump.
Old Oct 28, 2008 | 08:45 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Boost reference your power valve to your intake to be more streetable. That would mean adding a vacuum port in your base plate. I'm in the process of doing this with mine. See my post on the Carb board. I posted 2 ways to do it, Holley's way and another way I found on another board.
For strictly 1/4 mile, which sounds like your carb is meant for (with no vacuum ports)- you really don't need to. Just plug both power valve ports, get a straight mechanical distributor, richen the jet sizes and go!
No need to boost reference your fuel pump unless you go with a centrifugal supercharger (aka BLOW-THROUGH application). Only exception might be as junkcltr said - if you're running N2O in your intake runners - maybe you do need to boost reference the pump in that case....don't know myself.
Remember - you're using this carb in a DRAW THROUGH application. Just like carbs were designed to be. You're not forcing air through the top, so aside from referencing the PV to the intake - it works just like a NA engine -You just need to richen the jets for the extra cubes being created by forcing more air in - under the carb.
There's a better resource on this board when it comes to Weiand 142's - Damon. He's played with them for awhile now, and has helped me quite a bit! And just as a disclaimer - I'm still learning myself, but I've done mega searches...good luck with it!!
Old Oct 28, 2008 | 09:02 PM
interesting...................ive been tryin go find any info about this subject................i planned to fatten up the jets if i didnt use a boost referenced power valve setup.........i run 72 primary and 80 secondary jets............i figured id run a 80 primary and a 88 secondary jet setup to make up for it
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
2012sergen11
Oct 13, 2015 07:38 PM
Damon
Sep 26, 2015 04:29 PM
lanceflame44
Sep 25, 2015 12:28 PM
