Wideband error with 110 lsa
Old Oct 30, 2008 | 04:53 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
How far off do you guys think my A/F gauge is with my 110 cam? 9 psi.
Old Oct 30, 2008 | 08:30 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Re: Wideband error with 110 lsa
No ideas? I'm running and tuning the car saturday. I'd like to get it as close as possible. I'm not highly skilled at checking plugs.
Old Oct 30, 2008 | 09:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It shouldn't be off by much where it counts when you're making peak torque.
Old Oct 30, 2008 | 09:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
idle it may not read true but its hard to tell. Depends on where your sensor is mounted and how much overlap is actually in the cam itself
But at cruise or any other higher rpm, its probly reading as good as it can get. Not all cylinders will run the same air fuel anyway so its gonna get a average reguardless of how much overlap may skew the results by letting fresh air past the exhaust valve.
you should be pretty close tho and safe enough to tune it
Old Oct 30, 2008 | 09:16 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Ok, thanks. I did notice that it idles best around 14.5:1. Which shouldn't be right.
Old Oct 30, 2008 | 09:24 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
thats not a bad spot to be. my car idles fine anywhere from 13-16 but i have it set near 15.0 for the most part.
Dont worry about idle air fuel, just give the motor what it wants to be happy. Too lean may make for hotter header temps but as long as the car is happy that is what counts.
Jorlain
Oct 8, 2015 01:57 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
3rdgenparts
Sep 28, 2015 10:47 PM
efiguy
Sep 27, 2015 01:30 PM
mfp189
Sep 27, 2015 09:25 AM
