305 TOP END PERFORMANCE HELP
Old Oct 5, 2008 | 09:37 PM
Camaroman575's Avatar
Car: 1988 Chevy Camaro
Engine: 305 V8
i have a 1988 camaro with a SB 305.
i want new heads, cam and intake manifold. i was thinkin all performer stuff from edelbrock. but idk.
does anyone have any suggestions? any help is great.
Old Oct 5, 2008 | 10:19 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Re: 305 TOP END PERFORMANCE HELP
Exhaust... IMO, Headers, Mid-Pipe, Hi-Flow Cat, and Catback System help the car the most out of any mod you can do. (I mentioned all the parts of an exhaust right?)
Old Oct 6, 2008 | 04:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Edelbrock makes good intake manifolds, that's it. Skip their cams. Heads are mediocre.
Don't get a "package". That's just marketing BS to ease their packaging, it's not really all that well designed to work together.
Start with exhaust.
Old Oct 15, 2008 | 03:06 PM
Engine: 305 V8
i have full exhaust. but now i want to do engine work. im going to put a 3.73 posi rearend on it in december. i heard it is bad to just put on a new intake or just heads or just cam. you do one thing you have to do another.
Old Oct 15, 2008 | 04:11 PM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
i wound not say "Have too"...its you "should"..for max performance
Old Oct 30, 2008 | 07:33 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
toss the 305 if $$$ permits. But if thats a no i would build it like a 350 so when you do get a 350 block you can just swap everything over. I would stay away from the 305.
Old Oct 30, 2008 | 08:05 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
you really have to tell us some goals or results you want and intended useage ( street, track ect)
Old Oct 31, 2008 | 12:37 PM
Engine: 305 V8
i want a faster street car
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
3rdgenparts
Aug 6, 2015 09:03 AM
