race gas comp?
Old Nov 11, 2008 | 11:16 PM
87draggta's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: Th-400
Axle/Gears: 4.56 Richmond Gears
race gas comp?
I know most everyone here uses there cars for street duty and thus wants to run off pump gas. However, with the amount of time I run my car I don't car to buy the 110. My question is how much boost can I run on 110 without an intercooler, with say 10.5-1 comp?
Old Nov 12, 2008 | 12:53 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: race gas comp?
For 10.5:1 on pump gas you're talking probably about 8psi, and they say every 2 points of octane is 1psi of boost. That would make me say you could do 16-18psi. I ran 10psi on 10:1 compression and a slightly larger cam last year just fine, and would've likely held up to the 16psi I run now if I had either pulled some timing or run race gas.
Jorlain
Oct 8, 2015 01:57 AM
mz92274
Aug 25, 2015 08:47 AM
Dialed_In
Aug 20, 2015 01:45 PM
355tpipickup
Aug 13, 2015 07:35 AM
