how did u wire ur nitrous arming switch?
Old Dec 22, 2008 | 10:05 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
as title says. im trying to see the different ways everybody has ran there switches for there nitrous. i wanna use a toggle to run it but sum run bothe toggle and push button. how do u do that?
Old Dec 22, 2008 | 11:25 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Re: how did u wire ur nitrous arming switch?
The arming switch simply enables the nitrous solenoids to be activated. The solenoids are usually turned on by a micro switch located on the throttle linkage. This micro switch can be replaced by a push button, fast and furious style.
Old Dec 22, 2008 | 11:59 PM
Engine: 355
can i just us a toggle switch instead>
Old Dec 23, 2008 | 12:07 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
The toggle switch is the arming switch. A second switch is needed to enable the solenoids.
Old Dec 23, 2008 | 12:11 AM
Engine: 355
o so y dont the instrucyions with the kit show u that u need two> it just shows on switch running em all..
http://static.summitracing.com/globa...a5055-snos.pdf
Last edited by billybob6110; Dec 23, 2008 at 12:14 AM. Reason: Automerged Doublepost
Old Dec 23, 2008 | 12:23 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Page 11 clearly shows an arming switch and a micro switch
Old Dec 23, 2008 | 12:24 AM
Engine: 355
ya but it shows one switch for the selonoida and arming switch. its all running threw one switch. wheres the other switch or button
Old Dec 23, 2008 | 12:28 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
You can replace the micro switch with a push button inside of your car so you can control when the nitrous comes on.
Old Dec 23, 2008 | 12:31 AM
Engine: 355
so can i just run it the way the instructions say? will it work the same? basically turning it all on and the at wot itll activate all the stuff?
Old Dec 23, 2008 | 10:19 AM
Slick89RS's Avatar
Car: 89 Camaro RS
Engine: TURBO 94 LT1
Transmission: T-56 6 Speed
Axle/Gears: 10 bolt 4.10
Yes, that's the same way mine is set-up, turn on the switch in the dash and as soon as you hit WOT the system activates.
Old Dec 23, 2008 | 10:24 AM
Engine: 355
sweet thats the way i wanted to run it. u run into any problems running it that way?
Old Dec 23, 2008 | 10:39 AM
Slick89RS's Avatar
Car: 89 Camaro RS
No, works great that way.
Just remember to turn the bottle on...did that once
At least its just running rich but it's a surprise when you slow down instead of accelerating.
Old Dec 23, 2008 | 11:59 AM
Engine: 355
Old Dec 23, 2008 | 06:38 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
irishhockey34 was referring to the microswitch. (Also known as the WOT switch) Same switch, different terms...
I used my rear window defogger switch on my RS for an arming switch. (Its on a timer, so I never forgot to turn it off, LOL)
Old Dec 23, 2008 | 11:53 PM
Engine: 355
thats a different idea, i like that
Old Dec 24, 2008 | 12:44 AM
EvilCartman's Avatar
Car: '82 Z28
I hate that feeling A kinked nitrous feed line, fautly solenoid or low voltage to the solenoid will also slow you down all of which has happened to me lol. Never have forgotten to turn the bottle on, whew!
Old Dec 24, 2008 | 02:10 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I tapped into switched 12V wire to the radio. It's hot only when the key is in and cranked.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
