blow through MAF.
Old Jan 25, 2009 | 02:07 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
blow through MAF.
Is the stock 88 MAF accurate in a blow through aplication? 6-8 psi. thanks in advance.
Old Jan 25, 2009 | 02:36 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: blow through MAF.
i am actually running a wells thick screen variant, but same question.
Old Jan 25, 2009 | 02:48 PM
tequilaboy's Avatar
Under as little as 3-4 psi boost, the stock maf will peg somewhere between 4,000 and 4,500 rpm.
The accuracy depends upon the actual sensor as the output varies among sensors especially at higher than stock airflow.
It is only the first of a few limitations of the stock MAF/165 ecm system which will limit the ability to properly fuel a boosted application.
There are a few ways to get around the inherent limitations of the sytem, depending upon which way you want to go.
Old Jan 25, 2009 | 05:09 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
I will be at WOT or close if I am above 4000 rpm, so it will be on tables by then and mostly ignoring the maf, from what I understand the maf is only really active at part throttle correct? In that case it won't really matter because boost will be so low it won't matter.
Old Jan 25, 2009 | 05:29 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
I was running 8-9 psi before winter on my procharger blowing through my new remanufactured MAF from Bosch and everytime i hit 4k my wideband went super lean and i even added 100% pe fueling from there and up and it still pegged the lean side of the wideband. So 730 with code59 coming in a week it is.
Old Jan 25, 2009 | 05:48 PM
tequilaboy's Avatar
This describes the next limitation one will encounter when trying to compensate for boost with additional fueling in PE mode. It can be corrected with some special programming. I know Blowerworks offers a fix for this.
Old Jan 25, 2009 | 09:25 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
You can't tune like that with a turbo setup, airflow is nonlinear to rpm. You either need a larger maf that can read that much or a turbo maf ecm like a gn ecm.
Old Jan 25, 2009 | 09:43 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
It is a supercharger if that maters, but what would you recomend? I am trying to decide if i put it before or after the SC, After would be much better for me if possible.
Old Jan 25, 2009 | 10:08 PM
bl85c's Avatar
Car: '85 maro
Ah, then you're in luck. Airflow should be pretty close to linear with a supercharger and you could get away with tuning it with the tables. Draw through with the iat sensor after the supercharger would be best, although the '165 ecm doesn't really use the iat for much. Being that the tpi maf is a heated wire maf you can run it in boost without it being terribly inaccurate, but I still think draw through is the best way to go. Do you have a wideband O2 sensor?
Old Jan 25, 2009 | 10:42 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
not yet, I have a NB guage, and FMU, to start, then i will be upgradeing to a wb02 soon.
And I am uning the film type maf, does that matter? I can find a bosh if ineed to. But like my wells.
Old Jan 25, 2009 | 10:55 PM
bl85c's Avatar
Car: '85 maro
You need to put it ahead of the supercharger then, frequency film maf's aren't accurate in boost.
Old Jan 25, 2009 | 11:03 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
well that sucks... thanks for the info.
Fanatic1074
Oct 2, 2015 03:47 PM
86IROC112
Sep 28, 2015 08:17 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
86White_T/A305
Sep 21, 2015 05:28 PM
90formulaVortec
Sep 3, 2015 09:26 AM
