how much boost?
Old Feb 9, 2009 | 09:30 PM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
how much boost?
How much boost could I run on a completely stock 305 tpi with 93 octane and not risk detonation? It's 9.5:1 CR with stock 58cc heads. I'm thinking about a turbo.
Old Feb 9, 2009 | 10:26 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: how much boost?
I'm going to say 10psi with an intercooler is the max I'd want to put to that, 6-8psi would be better for avoiding issues at least to start with.
Old Feb 10, 2009 | 12:01 AM
gp90gta's Avatar
Car: 1990 GTA
Re: how much boost?
i agree 8psi,unless u o-ring the block or use a copper head gasket.Are u using efi or carb? I recomend 4 degrees retard for every pound of boost and 11 to 1 A/F/R at w.o.t,Should control detonation with no problem with that CR.Maybe even 10 psi i just dont know the altitude in mississippi
Old Feb 10, 2009 | 06:49 AM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
Re: how much boost?
i assume its TPI, if its completly stock 305CI...?
if so id stay at about 8psi, i ran 10psi on about 9.1/9.2:1 on 93octane, (stock 350, felpro stock replacement head gaskestes, only inetrnal mod was a smallllll turbo cam) with an intercooler but also am using a blowthru carb which people claim also cools the boost entering the motor by adding fuel slightly earlier then efi... just my 2 cents.
you could try using water/meth injection and crank the boost up to 15/18ish see what the 305 can do.
oh yea... i have ha dgood luck avoiding detonation by dropping a couple heat ranges on the spark plugs, kinda cheap way to help keep the pistons intact.
good luck
$750 L98
Feb 1, 2025 02:25 PM
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
