upgrade procharger?
Old Feb 25, 2009 | 01:05 PM
mr-zr's Avatar
upgrade procharger?
search for Cog Style Supercharger Pulleys for camaro 92. ore 8 rib for more boost.. any one how know wher can bay that?
Old Feb 26, 2009 | 05:46 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: upgrade procharger?
Procharger sells 12ribs pulleys and I think Larry at ASSC has a custom kit for procharger with cogs.
/N.
Old Feb 26, 2009 | 09:51 AM
Beater79TA's Avatar
Larry at ASSCRacing.com can set you up with a cog kit. Looking at the picture you posted, you'll have a bit of fab work to get it to fit around the upper radiator hose.
Old Feb 27, 2009 | 11:26 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Look into getting a cog kit, 12 ribs are kind of a pain in the ***.
Old Mar 12, 2009 | 07:06 AM
mr-zr's Avatar
yes whant cog kit but can't fund eny..
Old Mar 12, 2009 | 08:17 PM
irocz43's Avatar
Heres my cog setup. It looks like you copied my motor! haha...
Old Mar 13, 2009 | 01:15 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
how much boost are you running? you dont really need a cog setup for low boost, i'm running 14#'s on an 8 rib setup
Old Mar 13, 2009 | 03:09 PM
mr-zr's Avatar
20psi 8 rib sux
Old Mar 13, 2009 | 06:56 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
20#'s is difficult with an 8 Rib, but it doesnt suck.
Old Mar 13, 2009 | 08:28 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Running a wicked 8 psi here with a 6 rib. Some say you lose 10% to slippage with a belt this small, but I'm noticing very little. Blower is maxed out.
Depending on hard you are spinning the blower, aren't cog setups tough on the crank snout?? I was thinking about upgrading and running about 14 psi, but a cog setup is EXPENSIVE, might as well sell it all and go turbooooooooo. For myself anyway.
Old Mar 16, 2009 | 06:36 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Using cogs on the street I would prefer something like this
http://www.atiracing.com/superpulley/index.htm
/N.
Old Mar 16, 2009 | 07:08 PM
TexasLT1's Avatar
Car: '92 RS
/N.
Exactly what I was going to post. I'm will soon be running a 12-rib setup on an F-1 Procharger. Just got to work on the duct routing
Old Mar 16, 2009 | 07:36 PM
AC's Avatar
AC
Car: Used to drive a camaro
I'm with GTA, IF I were going cog, I'd get that piece for sure! Expensive though, through Summit there around 400bux just for that piece!! Then you have to get the crank pulley still, fab work etc. BUT, no slippage
Old Mar 17, 2009 | 12:51 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I use a procharger F1 with 12rib and so far I've made my own spring loaded tensioner to prevent slippage, it works good but the whole bvracket tends to flex so last year a new "bracket" and rerouted the belt so the bracket woulndt flex, the ATI constuction isnt that great when It comes to big power setups.......
/N.
Old Mar 17, 2009 | 10:57 AM
mr-zr's Avatar
money is not a problem.. whant no 12 ore 20 rib.. whant cog belt.. but if ther is no kit so im build my one.. just more fun =)
Old Mar 17, 2009 | 01:00 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I would highly recommend you going with a BBC crank snout or using that clutch gta recommended.
You will break your crank/key/hub with a cog and high boost.
Somebody makes a cog system.
Old Mar 17, 2009 | 01:33 PM
mr-zr's Avatar
oki. just whant garanty that the system dont slipp. my system now just slipping over 10 psi.. grr hate that. and think cog system tant slip. and im got my 20 psi.
Old Mar 17, 2009 | 03:07 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Cog may kill your crank................Talk to Larry at ASSC he makes a cog kit if you dont want to DIY, but If you do go with cogs consider the pulley I posted.........
/N.
Old Mar 17, 2009 | 04:12 PM
Beater79TA's Avatar
If you're going to street drive the car, spend the money on the ATI blower pulley. I ordered one about a month ago for the F1A on my car for the specific reason of not forcing the blower to hard stop which can result in damage to the blower and the crank if it's spinning fast enough when the belt suddenly stops.
The only real downside to the ATI sprag clutch super pulley is it only comes in one size so any changes to boost levels have to be done by changing the crank pulley.
Old Mar 17, 2009 | 04:46 PM
mr-zr's Avatar
oki and whats size is that? dont have space for that on crank :P
Old Mar 17, 2009 | 06:30 PM
Beater79TA's Avatar
The ATI Super Pulley with the clutch drive to allow the blower to continue to spin when the belt stops turning it (ie. rapid deceleration) only comes in a 45 tooth cog for on the blower. That means the only way to change boost levels is to change out the crank pulley to a different size (example: moving from a 66 tooth on the crank to a 77 tooth on the crank) This changes the overall diameter of the crank pulley but not the thickness (IE: the crank pulley will always be about 3 inches thick for a cog pulley)
For what it's worth, to get the cog setup to fit, I had a custom radiator made to move the upper radiator hose out of the way of the blower cog. If you are running the stock fans on the radiator, you will likely need to replace them with a low profile aftermarket fan set to clear the cog pulleys and idlers.
If you haven't already done it, do a search on this forum for the word "cog". There are some old posts by ***** that will give you a good idea what it takes to make a cog setup fit due to the thickness of the pulleys used in a cog setup.
Old Mar 18, 2009 | 12:26 PM
mr-zr's Avatar
ok thanks for that.. =) check that.
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
-=Z28=-
Sep 24, 2015 10:21 AM
