Whats used for timing and fuel?
Old Mar 8, 2009 | 05:01 PM
areonic1's Avatar
Im just wondering what you guys use to adjust your timing and fuel when you turbo. Like do you put a stand alone in, do you use stock ECU with adds. What do you use, etc.
Id appreciate any info I can get, Thank you
Old Mar 9, 2009 | 10:15 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: Whats used for timing and fuel?
I repinned my car for use with the 59 code from http://www.code59.org using a GM 730 ECM. Basically converted the car over to the 91-92 SD system with a few more pin changes and new code.
BTW wideband O2 is a must!
Old Mar 9, 2009 | 06:47 PM
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
i run the same thing on my turbo car. a 730 ecm with the code59 def file installed in it. It is good up to 30 lbs of boost. so far working but not as easy as 8d which i am used to tuning and ee lt1 stuff but it is working . and tony89gta i have the new afr eliminator heads on mine and they are sweet. I had a old set of afr 190s on my lt1 and these are so much better especially the new ls1 style valve guide size and small springs they use. I got the ported ones and flow right at 300 cfm at 650 lift.
Old Mar 10, 2009 | 07:29 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I'm using a stand alone - the Holley commander 950 ecu. It's very user friendly and changing the fuel and timing tables are easy. The hard part is finding what your engine wants.
Old Mar 10, 2009 | 09:54 AM
Tony89GTA's Avatar
Car: 89 GTA
Ah sweet your using the competition heads, wish they had that when I ordered mine
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
