autotune not working right or that stupid?????
Old Mar 9, 2009 | 05:07 PM
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
i cant seem to get anyone to answer over at code59 so figured i will as here. i have over 3000 samples that i put into autotune and it only picked 25 or so to change. out of those most are in boost. I watched it idle rich and drove around with it lean and it didnt fix any of it so is this program that dumb and have to do it hundereds of times to get things changed or is something wrong.
Old Mar 10, 2009 | 01:43 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: autotune not working right or that stupid?????
I posted this in the code59.org forum ( that I cant acces anymore...)
The "problem" with autotune 1.5 was
- If PE is enabled under 99kPa the Autotune didnt look at theese values.
I have a updated autotune 1.6 that take care of the problem, where you can put in where you want your PE to enables. I emailed it to Paul@code59 you could ask him for it or email me at gta324(at)hotmail. com and I can send you a copy.
/N.
Old Mar 10, 2009 | 03:38 PM
lt1z350's Avatar
pm sent
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
gta power
Aug 13, 2015 06:15 AM
