Procharger P1- SC Carb setup
Old 03-19-2009, 04:39 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
So Ive been thinking of running a P1-SC for my car. I have a 750 holley carb, trick flow heads and cam and the other basics. I was wondering if anyone has done this that could help me out with some stuff I might need. Ive heard something about a blow threw carb? Some help is needed. thanks
Old 03-19-2009, 07:20 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Procharger P1- SC Carb setup
jimmy u can do it just call procharger and they can set u up with a carb kit you would need a blow thru carb casue its referenced for boost
Old 03-19-2009, 07:24 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
could i just get and swap the main body with a blow threw design or do i have to buy a whole carb. second question is what will happen if you didnt use a blow threw carb?
Old 03-20-2009, 08:07 AM
sailbrd's Avatar
750 is a good carb for blow through. According to ATI if it is an HP carb all you have to do is rejet. Not sure about this myself. You have a carb that works well judging from your times. One of the good carb shops should be able to mod your carb as needed.
Old 03-20-2009, 11:29 AM
tom86iroc's Avatar
Car: 1986 iroc
jimmy call holley up ask them about the carb but im almost certain a reg carb looks for vacuum and when you add boost it doesn't see that i'm not sure but call them i'm sure they can help ya
Old 07-16-2009, 11:02 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
I'm running the ProCharger v-belt carb setup with a Holley 750 DP with HP main body (don't use Proform main body, very bad casting). You'll need to do some modification to the carb to handle boost, here's a good source but search around, http://www.hangar18fabrication.com/blowthru.html. You'll have to run a compact power steering pump with remote reservoir. I'm using the ProCharger bracket for that.
Old 07-21-2009, 04:03 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
ive decided to go a different route and do a nitrous LS1. Thanks for the info all
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
86Firebird86
12-26-2015 07:21 AM
makaveli09
09-15-2015 10:43 AM
rjcme
09-05-2015 01:23 PM
GeneralIesrussi
09-03-2015 03:23 AM
Quick Reply: Procharger P1- SC Carb setup
