Nitrous Jetting Concerning Fuel Pressure
Old Apr 22, 2009 | 09:56 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
I am about to bolt in a AFPR on my TBI Camaro. Question is if fuel pressure is raised from the stock ~12psi to say ~22psi, would the fuel jet in the nitrous plate have to be swapped out for a smaller jet to ensure air/fuel mixture? Thanks.
Old Apr 22, 2009 | 10:47 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: Nitrous Jetting Concerning Fuel Pressure
I wouldnt think so, the nozzle only allows so much, and the solinoid does all the work anyways.
Jay
Old Apr 23, 2009 | 12:42 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Jay
this is completely WRONG. the solenoid is simply an on off valve. do your homework on how nitrous systems work.
this is an NOS plate kit correct? if so your best bet is going to be to call or email NOS tech department and tell them what you're doing. you're going to need to go to a smaller jet spread on there to get the F/N ratio correct. but like i already said, i'd call up NOS and see what they recommend.
Old Apr 23, 2009 | 12:44 AM
fenton06's Avatar
Yes, and a +1 for calling NOS.
Old Apr 23, 2009 | 02:20 AM
Jay_rich's Avatar
Car: 1987 Z28
kinda what i meant but explained it wrong, the solinoid clicks open to allow fuel, but wouldnt the jet only let in so much?
PS i have had a nitrous kit on my car, but took it off since its a pain filling a bottle all the time.
Jay
Old Apr 23, 2009 | 09:57 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
it'll only let in so much, but that "so much" is increased as you increase pressure. think about a garden hose, just crack the valve open and look at how much comes out. how open it up completely, you see what i mean? this isn't a perfect analogy but it will give you an idea, the same size opening is letting a lot more through
Old Apr 23, 2009 | 01:26 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Thanks for the quick response guys.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
