why cant i make up my mind??
Old Jun 2, 2009 | 08:10 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
i did all the research to put a 383 stroker in my car, about 500fwhp with afrs 195s yadda yadda. I had it all down and i even narrowed it down to the last bolt but now i just started thinking afr heads are about 1500bux, i think i might be able to piece a turbo kit for that amount and just put it on my healthy 350, why take appart something that is running great?
I am going with a single turbo, this is the one i am interested in its a t76, i am planning on starting with around 7-8psi to get the feeling of a turbo v8, which i heard is nothing like a turbo L4 or V6 (what ive had, hence my user name)
Intake :3.95 inch
Outlet: 2.5 inch
Compressor trim: .80 ar
Compressor Wheel diameter 76.80mm / 102.35mm
Turbine Wheel diameter 72.78mm /64.20mm
Exhaust trim: .81ar
Turbine flange type: t4 flange
Downpipe flange type : 3 inch v band flange
Cooling type: oil cooled only
and the carb i will be going with a mighty demon what size would be sufficient, i was thinking somewhere around th 800cfm area?
so will the turbo be ok? and what size carb?
engine is a 350 with flat tops, 64cc comp around 9.2:1
thanks
Old Jun 2, 2009 | 12:15 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: why cant i make up my mind??
yes a T76 would be perfect! everyone told me go with a T6 on a 383, if u street drive alot I would say a T4 flage is fine. If I did it again id prob go T4 bc of clearence!
Mine is a 74MM with a T6 flange, see boost around 3800rpm
Jay
Old Jun 2, 2009 | 04:01 PM
sweet thanks for the reply. are you fuel injected or carb??
i just need some advice on the carb now??
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Thornburg
Aug 30, 2015 08:05 AM
someone972
Aug 30, 2015 12:52 AM
sreZ28
Aug 14, 2015 07:48 PM
