evac pumps...
Old Jun 1, 2009 | 08:38 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
evac pumps...
at what hp level are you guys using EVAC pumps?
im only at 7psi on my 355ci, estimated 520ish crank hp and my engine seems to be pushing oil threw a few of my gaskets, at fisrt everything was fine and after some hard passes under boost it seems to be seeping quite a bit of oil....
the engine was just rebuilt, everything was cleaned and installed properly with new good quality gaskets...
what evac pumps are people using for street driving?
Old Jun 2, 2009 | 02:33 PM
jonarotz's Avatar
Car: 91 Z28
Re: evac pumps...
I had an issue with this, I chose to install a moroso breather can and just ran a line from each valve cover to the can. Problem solved.
Old Jun 2, 2009 | 04:34 PM
Car: 91 camaro rs
Re: evac pumps...
okay... i know what you mean, do you have a part number for the one you used?
also id be interested in your combo and results.
power and engine components, etc... you can pm me or email if youd like. thatd be awesome! thanks keith
kburch5647@yahoo.com
Badass355ciz28
Sep 28, 2015 08:31 PM
YenkoST
Sep 22, 2013 05:36 AM
daves12secV6
May 7, 2007 11:54 AM
1fast97gsx
Jan 16, 2007 01:35 PM
