fast twin turbo question
Old May 30, 2009 | 06:27 PM
5.0slayer's Avatar
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
im new with turbos and building a 355 with all forged parts and a built th400, now i have the turbo headers just wondering if the t3 turbos off of the ford turbo coups would work fine to use , i really need to no fast due to im going to look at the turbos tomorrow, and im getin a hell of a deal both for only 75 and they were just rebuilt. i got a friend that works rebuilding them
Old May 30, 2009 | 09:33 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: fast twin turbo question
Having used t3's from a Chrysler (nearly the same as ford) on my camaro, I wouldn't do it again. They choke the motor really bad at only 5000rpm. The price sounds ok, though.
Old May 30, 2009 | 09:43 PM
5.0slayer's Avatar
Car: 91 camaro RS
is there not any thing i can do for it not to choke up, and how bad is the choke ,
Old May 30, 2009 | 11:16 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
Engine: 383 waiting on afr 195 comps
Axle/Gears: 3.42 Posi
Make sure they are the 60/63 turbos. That is to say that the exaust housings are an ar 63, not the ar 48s that ford and mercury put in the auto trans cars. They used the 48s for faster spool up in the autos. The 63s will give you much less "choke" and you will make power to 5500 or so, wich is all you really need to get to the 500-600 hp MAX range. Oh and this is a much bigger turbo than the chrysler t/3s. At this hp i would say a good set of forged pisons and rods would be plenty to support that power goal. Hope this helps.
Old May 30, 2009 | 11:32 PM
I wouldn't say "much bigger", its 50 trim versus 60 trim, but a little bit bigger none the less. I agree, if they have the .63AR turbine housing they will be worth getting.
Old May 30, 2009 | 11:40 PM
5.0slayer's Avatar
Car: 91 camaro RS
well im gona buy them reguardless and if there to small ill sell them to the first civic i see at the strip that slow, witch shouldent b hard to find at all, but i do no they r off of the mustang svo 5 speed turbo cars, just dident think about it being different from auto to manual,
lots of help guys thanks
Old May 30, 2009 | 11:41 PM
5.0slayer's Avatar
Car: 91 camaro RS
o and 5.0eater was the first name i tryed when i joined no i no y it wouldent let me have it lol
Old May 31, 2009 | 06:43 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
Yeah I accually got some crap for using that name from the 5.0 tpi guys. like a 5.0 tpi should even be worth eating. lol
Old Jun 1, 2009 | 07:54 PM
5.0slayer's Avatar
Car: 91 camaro RS
ha yeah i was talkin about the 5.0 rustangs,
but i went and looked ta the turbo and holy **** they were small , they were the a\r .48. they looked as if they wouls choke the lawn mower, the intake was like maybe 1.5 in in diamator
Old Jun 1, 2009 | 08:03 PM
I take it you didn't buy them?
Old Jun 1, 2009 | 08:12 PM
5.0slayer's Avatar
Car: 91 camaro RS
o no i mean thet wewe so little my friend looked and said "well these are cute". i c where you got the choke, but i was also reading and is it true that none of the twim turbo headers will b a bolt on?
if this is true would it b better to build a single turbo set up wuth one holset turbo i can get the turbo for 100 to 125 rebuilt, no w\g, but how would i run the pipeing to the turbo with the stearing linkage and the the down pipe with the fire wall and headers in the way on both sides, but lookin to cut away the fire wall and run a 3in down pipe
Old Jun 1, 2009 | 08:17 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Since they were not as advertised I would be wary of any person that supposedly works rebuilding them. I wouldn't buy any advertised turbo(s) from them unless you know yourself what you are looking at.
As for your setup a pair of T3 60 trim, .63 A.R turbines would work good.
Old Jun 1, 2009 | 08:19 PM
junkcltr's Avatar
Engine: 3xx ci tubo
What size/series holset turbocharger? The piping will fit, but things get tight.
Old Jun 1, 2009 | 08:43 PM
5.0slayer's Avatar
Car: 91 camaro RS
its a holset hx 50 i believe but he also has a hx30-35? not sure but its off of a dodge its a 3in intake and exhaust, i can also build my own cross over i woek at a shop that does exhaust and can get a 13 ft pipe for like $23 any size i want and bend and weld, its just where to run the pipes every one has great pics of the single turbo but there all out of the car, i need good pics of singles that show how to do the pipe under it
Old Jun 1, 2009 | 10:39 PM
BBS designs still makes bolt-on turbo headers last I heard.
Old Jun 2, 2009 | 06:30 PM
5.0slayer's Avatar
Car: 91 camaro RS
could any one post a link for me?
and also with me workin at a shop is it possible to use the shorty headers and make a coustom y to the turbo
Old Jun 2, 2009 | 08:44 PM
5.0slayer's Avatar
Car: 91 camaro RS
i found it on another post on here
http://www.xs-power.com/gm-turbo-manifolds-3.htm
am i the only one who thinks it will hit the ac even with the bypass pully on it?
and here is a pic of the space between my passenger header and fire wall, there ante nothing goin in there without something being cut.
bjpotter
Jan 22, 2019 12:27 PM
Fast355
Dec 2, 2016 06:33 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
PestilenceIV
Aug 20, 2015 03:32 PM
redmaroz
Aug 16, 2015 11:40 PM
