Boost EVAC crankcase setups
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
What are y'all running for boosted setups? At the moment, I'm running a breather on the rear of the passenger side valve cover and then one tube on the front of each cover to a breather tank vented to air. I know there is a better way and probably need to evac it back into the engine might be better as well.
Let me know or see what y'all got!
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: Boost EVAC crankcase setups
Filtered breather on the passenger side and stock PCV setup to the intake manifold.
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
breather on each valve cover to a oil catch canister
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Lines from each cover into a ventilated catch can. If i find a strong enough check valve i will go back to a pcv valve setup. Stock valves are a joke
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
I have a billet specialties breather on the passenger side and billet specialties breather with a built in PVC valve on the drivers side that is plumbed back to the intake manifold. Haven't had any issues so far, works great!
Car: 88 GTA, 74 T/A
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Looks like we are all running about the same setup. Just wondering if there is a better way or is what we got about the best way to do it without a vacuum pump.
Car: 89 Iroc-z
Transmission: TH400
Well I think a PCV is the best but the key for a boosted build is to prevent backflow from the intake pressure. Thats why I need to find a checkvalve that can handle 25psi which will be my limit I think
Only other way to overcome that is to run the vacuum line to the suction side of the compressor. I dont know how much suction/vacuum is applied on that side of things and to be honest, if there is alot of vacuum there, then your filter is a restriction and needs changed. Plus you'd need a air/oil separator to keep oil out of your compressor wheel.
So I'll be looking for a good checkvalve that can stay shut at 25 psi and open easily with fairly low vacuum from my big cam.
But the vented covers and catch cans work fine. I rarely see much fluid in the can, and its mainly just condensation. Just change your oil more often as the crankcase fumes that do not get extracted will deteriorate the oil over time.
Only other way to overcome that is to run the vacuum line to the suction side of the compressor. I dont know how much suction/vacuum is applied on that side of things and to be honest, if there is alot of vacuum there, then your filter is a restriction and needs changed. Plus you'd need a air/oil separator to keep oil out of your compressor wheel. So I'll be looking for a good checkvalve that can stay shut at 25 psi and open easily with fairly low vacuum from my big cam.
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
I run a 7.3 ford mechanical vacuum pump pulling from one valve cover and an open breather in the other valve cover. Had it working for about a month so far been working great. Had some issues using oil through the pcv even with a catch can. Also for reference, gm# 20861501 check valve I use can hold around 30 psi. Most dealers have it and its fairly cheap too, under 10 bucks. Stumbled upon it in ls1tech.
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I just have a PCV valve in each valve cover with the hoses vented to atmosphere at this point. I will eventually route them to a catch can, but for now they don't make too much of a mess
-Paul
-Paul
Car: 89 GTA
I'm going to give that check valve a go too, looks like it would work. I know the stock PVC valve leaks a bit under boost but I never had a problem with that setup over the last 9 years.
Ive got passenger side with a breather and a pcv with a hose that goes into the intake piping before the throttle body. I have a feeling thats wrong for boosted setups (it does have a check valve, but still). I noticed some blowby coming out the breather..should I look for a catchcan setup or vacuum pump?
Car: 89 GTA
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
