Help With Cam For Twin Turbo
Car: 88 TA
Engine: 5.7 TPI
I have been reading and looking and pulling hair and cussing. I cant seem to key in on what I need in terms of a cam. Here are my engine specs and a couple cams I was looking at.
Twin Turbo (Garrett T04B) 14# boost total
355 all forged 3.48 stroke
I would prefer a solid roller but how will that effect the knock sensor?
Lookin at some of the cams comp has. After talking to them they should be able to cut a solid roller close to the hydraulic specs. Its quite hard to figure out what to use and I would prefer to not guess. Help needed thanks!!!!
Pro Street applications, excellent for multi-stage kits or 671 blower. 2800+ stall.
HYDRAULIC
RPM 2800 to 6800
@.05
240 253
LIFT .507 .525
SEP 113°
Good for serious street/strip applications with 671 blower.
MECHANICAL ROLLER
RPM 3000 to 6500
@.05
255 262
LIFT .575 .575
SEP 114°
HYDRAULIC
RPM 2800 to 6800
@.05
240 253
LIFT .507 .525
SEP 113°
MECHANICAL ROLLER
RPM 3000 to 6500
@.05
255 262
LIFT .575 .575
SEP 114°
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Help With Cam For Twin Turbo
What kind of car is this? Track only? Street/strip? Is it manual or auto? If auto, what size stall? What heads do you have? I'm not really a cam guy, but you need to tell others more info on your setup to get recommendations.
Car: 88 TA
Engine: 5.7 TPI
Its a 88 formula T56 with corvette aluminum heads. I know I should get better heads but that's what I have for now. Street mild strip.
New2Chevy
Sep 28, 2015 12:35 AM
