Can't find colder shorty plugs
Old Aug 23, 2009 | 11:04 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I'm finally installing the B&M blower and I don't think they sell colder shorty plugs than what I'm using (0574S). Its a goodwrench motor (8:1cr) with an XE262-4 camshaft. Any idea if these plugs'll be fine with the blower? I should be able to read them right?
Old Aug 25, 2009 | 12:35 PM
trumps2000's Avatar
Car: 1985 Z28
Re: Can't find colder shorty plugs
no one?
Old Aug 25, 2009 | 04:56 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
i use ngk's, but i don't have a blower...
Old Aug 27, 2009 | 10:42 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Those are the shorty accel plugs right? If so they are heat range 4, stock is 6 so you are two steps colder. depending on how much boost you run you should be ok. My buddy is running heat range 4's on 16lbs from an intercooled procharger and it is working great.
Old Aug 27, 2009 | 01:16 PM
trumps2000's Avatar
Car: 1985 Z28
Sweet, good to hear, Its weird that for some reason Jeg's recommended this cold of a plug for this stockish low compression motor.
Old Aug 28, 2009 | 03:14 PM
Beater79TA's Avatar
Yeah, it's running pretty good on heat range 4. Try the Autolite plugs. They have an installed height just as short as the Accel shorty plugs and are much easier to get. NGK plugs were just as short as well but not available to me locally in heat range 4.
The easiest way to find them is go to Summitracing and look up all the heat range 4 plugs from the manufacturer you want in the correct size and reach and then go to the local parts store and compare them to the installed height of the Accel shorties. That's how we found the Autolites for the 92 and a set of NGK's for the 88 to replace the Accel shorties.
Old Aug 28, 2009 | 04:45 PM
trumps2000's Avatar
Car: 1985 Z28
Good to know. I started to compare heat ranges between the 2 and found with NGK lower means hotter and vice versa for Accel. Confusing, but I can cross reference them.
Old Aug 28, 2009 | 05:19 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
they're still making the Accels?
Old Aug 28, 2009 | 05:30 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
Yup.
eightsixseven
Dec 16, 2024 01:50 PM
LilHot
Aug 23, 2015 09:36 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
apie2546
Aug 8, 2015 07:12 AM
