401 Twin Turbo start up vid
Old Aug 26, 2009 | 06:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
http://www.youtube.com/watch?v=FjDyKQftSqc
It runs for now but soo much more to do with the tune. Its coming around but taking longer than I expected. Trying to get the hang of this code $59 stuff. Idle is a touch higher than wanted, at about 950-1000 rpm now, hoping for a bit softer lopier 850 or so but I cant complain with 80lb injectors.
Car isnt as quiet as i expected for a lower compression motor and a less agressive cam. Well i guess a 233/233 on a 112 with .564" lift isnt that mild but its a 401 motor. My 383 had a 230/245 on a 109 with over .600 but with 11 to 1 compression. Same exhaust on this car minus long tubes basically. Muffler back is same as last year, just new y pipe but still 3" tubes to 4" single dynomax ultraflo round
Old Aug 26, 2009 | 08:33 PM
Z28IROC's Avatar
Car: 1988 IROC
Engine: 350CI
Axle/Gears: 9 bolt 3:70
Re: 401 Twin Turbo start up vid
Sounds great. Glad to see you got it running. Can't wait to see how it runs.
Old Aug 26, 2009 | 09:51 PM
SilentBobZ28's Avatar
Car: 2014 2SS/RS
Engine: LS3
Transmission: TR6060
Axle/Gears: 3.55
Looks killer man. You have definately stepped it up to a new level. I'm probably gonna be leavin the 3rd gens soon. I want to build a 418 Blower motor for my challenger. So I've already sold my procharger off my camaro. Next thing to go is the boxes of and boxes of parts and the car.
Old Aug 26, 2009 | 10:49 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Wow great looking setup! Looks like you are having a much better time with Code 59 than I did. If I could have gotten mine to run I'd already be driving around with the turbo on mine, but had to take the megasquirt detour and spent my funds on that stuff. Anyway, from the looks and sound of that car, it should be a real runner! Can't wait to see some more vids of it.
Old Aug 28, 2009 | 02:08 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Glad to see it running!
Old Aug 28, 2009 | 04:52 AM
ScottyRock's Avatar
Car: 92 L98 Z28 Heritage Hard Top
Engine: L98 350 w/ HSR,24lbs inj,AFPR
Transmission: TCI Super Street Fighter W/3300 sta
Axle/Gears: 3.73 Detriot NoSpin,LPW cover
Very nice, how do you like the SHP block? I am thinking of Dart SHP or Motown as I have Motown 220 heads. Good luck BEAUTIFULL CAR
Old Aug 28, 2009 | 06:35 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
SHP block is a nice block. Great deal for the price I think. Its setup like a factory OEM roller block but its much stronger. Plus it comes in a 400 bore so its a better platform to build a 400-406 sbc off of than a gm block.
Old Aug 28, 2009 | 07:36 AM
pearlphoenix's Avatar
Car: 86 Trans Am
Engine: 383
Transmission: Probuilt 700r4
Axle/Gears: 2.77 BW 9 Bolt
nice work ive been following this for some time now, always impressed with your work, hope to see more soon.
Old Aug 28, 2009 | 08:26 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Sounds and looks great. Cant wait to see what it runs.
Old Aug 28, 2009 | 12:03 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Given the choice, I probably should have went with those.
Lot of machine work and 'fixes' to my GM 400 block. Then special lifters to make it roller if I want to do that.
I'm a little screwed on the came due to rod clearance. I think most roller cams will whack the rod, even flat tappet cam I need a small base circle.
-- Joe
Old Aug 28, 2009 | 12:16 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
Awesome job! that things gonna be a handful!
Old Aug 30, 2009 | 08:16 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
sounds great man! cant wait to see the dyno and track numbers!
Jay
Old Aug 30, 2009 | 10:30 PM
ScottyRock's Avatar
Nice to hear, might get one after tax season, NICE Build
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
PestilenceIV
Aug 20, 2015 03:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
