no fuel pressure under boost
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Well, I was trying to get my car tuned today and the car ran fine,but as soon as it went into boost the fuel pressure gauge is showing the fuel drops to zero.
I have recently around 2 months ago changed my pump over to a bosch fuel pump from tpis.com. My setup also is 42lb svo injectors with with holley adjustable fuel regulator with procharger fmu. i am running stock fuel lines and stock fuel filter. any ideas anyone? other info on the car is in my sig.
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: no fuel pressure under boost
are you using a booster pump ?? you could be using all the fuel in the line and psi is dropping what model pump
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
It's a Bosch pump from tpis that is rated to hold up to 850hp
Car: 1986 iroc
ok how about when your driving along how much pressure do u have then? u have a fuel press. gauge in the car?
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
when i am driving along i have around 60 to 70 then when i nail it it drops down to zero,but recovers real quick.
Car: 1986 iroc
sounds like the fmu is bad or not hooked up correctly def. don't wanna lean any car out under boost
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Also check the lines so they dont are squezed or bent, so they are a restriction for the flow..
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
you don't need a regulator and FMU. If you are going to tune it in the computer, throw away the FMU.
Car: 1986 iroc
if he doesnt use a regulator what controls fuel pressure?
Car: 86 MCSS-87 Z28
The FMU is a fancy fuel regulator. It increases the fuel pressure as it senses boost.
9192camaro
16
Feb 3, 2019 12:21 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
