Inline boost pump never shuts off with ignition on
Old Sep 29, 2009 | 06:59 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Do all boost pumps constantly run?
Old Sep 30, 2009 | 10:16 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: Inline boost pump never shuts off with ignition on
If you wire it to ign voltage it would. The only way to have it come on only with boost would be to run a hobbs switch. Then you might run into it restricting the in tank pump though. I can look in the procharger installation instructions, but I am pretty sure it's supposed to run at all times when the car on.
Old Sep 30, 2009 | 06:29 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Ok thanks
Old Sep 30, 2009 | 10:47 PM
glock's Avatar
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
while the car is on ... the inline booster pump is also on \
Old Sep 30, 2009 | 10:55 PM
The procharger instructions say to wire the relay that turns on the inline booster to the gray fuel pump wire. That would mean anytime your fuel pump has power, the inline booster would be on. So your system is correct.
9192camaro
16
Feb 3, 2019 12:21 AM
anesthes
Aug 24, 2015 08:18 PM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
djmarch
Aug 9, 2015 05:27 PM
