New Ls supercharger
Car: 91' Formula/88' Formula
Engine: 5.7L TPI/ 5.7 zz4 with mini ram
Transmission: 700r4/Stock T5
Axle/Gears: 10 bolt 3.23 /9 bolt 3.70
New Ls supercharger
Is anybody using this charger on their 3 rd gen
http://www.gm.com/experience/technol...Industrial.pdf?
And does anyone know if this is available on any street cars/trucks?
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: New Ls supercharger
That could be pretty cool. You'd have to have a serious cowl hood to house that big bastard. I bet it makes boost pretty damn low in the range.
An industrial engine that makes 1k ft/lbs of torque, **** dude you pull a house with that damn thing!
NO that graph is a misprint. If u look at the specs on the side peak torque is 395
It says torque is 395 @ 2k rpm The engine is fuel limited to 5600 RPM's. Most industrial engines are not ran at like 5k rpm because the fuel consumption would be through the roof. Also things the are designed to be driven like with an engine like this (ie an electrical generator) aren't meant to be spun at that kind of RPM.
Ya you're right 3rd gen will, i was reading it wrong... looks like about 250hp peak and 1000lb/ft at 5000 holy **** That thing keeps pullin and pullin
I know the new zr1 's are supercharged, I wonder if its the same charger?
toronto formula
11-10-2015 06:17 AM
