125shot on 305
Old Oct 25, 2009 | 09:30 PM
gofastbird's Avatar
125shot on 305
Looking to get heads and cam done soon...Any suggestions on set of heads and cam to run with a 125shot. The car only has 33k on it.
Old Oct 26, 2009 | 11:40 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: 125shot on 305
I would tailor the heads and cam together with my intended RPM. Nitrous will be used 1% of the time the car is running. That being said I ran a 150-175 shot with vortec heads and it worked quite well.
Old Oct 26, 2009 | 11:59 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: 125shot on 305
If your jet chip advances timing, find out and account for it when you reatrd the timing with nitrous...
Raf
Old Oct 28, 2009 | 01:46 AM
t_long927's Avatar
Re: 125shot on 305
Well with my experience with nitrous you can run up to 125shot without much add ons. When you buy the Nitrous kit it will tell you, the most important thing is to make sure the engine does not burn oil at all..... If it does than it can cause premature dettenation. You don't want that. So take that in consideration. But Nitrous is one of the safest power adders money can buy. Oh and make sure those head and manifold bolts are tight....
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
