New F4 Geardrive setup from PRI
Old Dec 11, 2009 | 12:28 PM
KS91Z28's Avatar
http://www.streetlegaltv.com/forum/h...able-4357.html
When I came over to the Procharger booth first thing Thursday morning, I thought this was some kind of cruel joke. A supercharger the size of a trash can attached to the front of a big block Chevy, and it is nearly half the size of the engine itself. This is the new Procharger F4 supercharger and it even requires a minimum of 900 naturally aspirated horsepower to make it work.
This blower is a gear drive only type system that is designed to make 3200+ horsepower, 45 psi, and flow over a hurricane-like 5400 cfm. The gear drive system on this blower is the same unit you will find on the F3. This is a limited production piece (obviously) and is designed for extreme drag racing. We heard that this blower was going to be tested soon, but no name was released. The one hint we had was “A previous NMCA Pro Street Champion”, which immediately leads us to think Mark Mickie.
You can barely see the engine behind the blower!!
"It's hard to believe that engine builders and racers are looking for even higher power levels and increased blower efficiencies than the F-3 models already deliver," says Jim Summers, Motorsports Director at ProCharger. "The F-3 has proven capable of 2,000 horsepower on pump gas and 3,000 horsepower on an engine specifically designed for use with a supercharger and running alcohol fuels."
Make sure your cat isn’t walking buy when you fire it for the first time, it might just suck it in.
NEW ProCharger F-4 Supercharger: specifications
Volute Diameter: 16-inches
Max HP: 3,200+ HP
Base NA HP: 900-1,400 HP
Max Flow: 5,400 CFM
Max Boost: 45 PSI
Inlet Hose Dia: 7-inches
Inducer Dia: 6.32-inches
Exducer Dia: 8.89-inches
Outlet Hose Dia: 5-inches
Outlet ID: 4.26-inches
Max Impeller RPM: 55,000 RPM
Internal Step-Up Ratio: 5.63:1
Reverse Rotation Available: Yes
Self-Contained: Yes
Oil Capacity: 4 ounces (larger capacity available for extended run-time applications)
For comparison: ProCharger F-3R-139 Supercharger specifications:
Volute Diameter: 12-inches
Max HP: 2,700+ HP
Base NA HP: 700-1,000 HP
Max Flow: 4,000 CFM
Max Boost: 45 PSI
Inlet Hose Dia: 6-inches
Inducer Dia: 5.47-inches
Exducer Dia: 7.20-inches
Outlet Hose Dia: 4-inches
Outlet ID: 3.59-inches
Max Impeller RPM: 62,500 RPM
Self-Contained: Yes
More information will be eventually found on www.procharger.com
Old Dec 11, 2009 | 02:21 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: New F4 Geardrive setup from PRI
insane.
Old Dec 11, 2009 | 04:26 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
I posted this too, it's right under this thread.
INSANE!
Old Dec 14, 2009 | 02:23 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
thats freakin amazing!
i actually thought about this a while ago, but of course on a more um... normal scale.
i wonder how the gear drive efficiency compares to a belt drive.
considering the flexing of the belt and the massive tensions required, i'd dare to say that it could be more efficient, but who knows.
900hp to make it work lol
Old Dec 14, 2009 | 09:46 AM
KS91Z28's Avatar
Yeah, sorry about that fly89gta. I didn't realize that 'til after I posted this then looked at your thread and noticed you beat me to it by like 30 minutes.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
