Help me decide
Old Dec 29, 2009 | 11:46 PM
jonarotz's Avatar
Car: 91 Z28
Help me decide
I was running a HSR setup with my twins, but I have the engine out AGAIN for some more improvements/mods. I was thinking of swaping to a single plane efi setup I had lying around so I built a custom air box for it, but I am not sure how I like it. With the new air box I am going to have to run a cowl hood or something. I think no matter what, the single plane intake is going to require a different hood regardless of the airbox design. The single plane intake should make more power and have better air/fuel distribution and is using a 1500cfm throttle body. Here are some pics, please give me some feedback.
Attached Thumbnails Help me decide-1.jpg   Help me decide-2.jpg   Help me decide-3.jpg
Old Dec 29, 2009 | 11:49 PM
jonarotz's Avatar
Car: 91 Z28
Re: Help me decide
couple more
Old Dec 29, 2009 | 11:55 PM
jonarotz's Avatar
Car: 91 Z28
Re: Help me decide
Previous setup
Old Dec 30, 2009 | 12:05 AM
Black_Knight's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305TPI
Re: Help me decide
What headers/manifolds are you using? Are they custom, or did you purchase them already made?
Old Dec 30, 2009 | 12:06 AM
jonarotz's Avatar
Car: 91 Z28
Re: Help me decide
Everything is custom and hand built by me. What manifold setup do you like better?
Old Dec 30, 2009 | 12:50 AM
Engine: 305TPI
Re: Help me decide
I prefer the previous setup. It also has the virtue of allowing for greater clearances and hood compatibility.
Old Dec 30, 2009 | 10:33 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Help me decide
I like the HSR look better and if you want more power install an intercooler.
Old Dec 30, 2009 | 11:41 AM
jonarotz's Avatar
Car: 91 Z28
Re: Help me decide
Ok so two votes for the HSR...thanks guys.
Old Dec 30, 2009 | 03:59 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Re: Help me decide
the hsr looks alot cleaner, i would say keep the hsr. i really like your setup very clean!
Old Dec 30, 2009 | 04:16 PM
jonarotz's Avatar
Car: 91 Z28
Re: Help me decide
Thanks man! I think I might just run the HSR again, I know it works and can still support the power. I was putting down 500hp to the wheels at 10lbs and I intend to step up the boost to put down 600hp to the tire and I think that intake can handle it. I can just save the single plane for another project down the road.
Plus I like keeping it all under the stock hood...sleeper.
Old Dec 31, 2009 | 01:34 AM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
Re: Help me decide
First, I think you did a very good job on that custom intake, I would use it IF i didnt have an HSR already.
Old Dec 31, 2009 | 06:39 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: Help me decide
I think you should keep the HSR, but that's only I'm biased maybe. I like the custom intake but for some reason, it just doesn't fit the car. Maybe make it a bit narrower and a lot taller, then it would fit the car.
Old Dec 31, 2009 | 11:33 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Help me decide
I like the HSR better but only if the air distribution is somewhat even. But you are using Gen 7 to tune it so its full sequential right? Do you have control to each injector? you can offset the fuel bias for any air distribution problems you may encounter with the HSR.
I ditched my HSR for singleplane because i got scared of the distribution problems since I planned on using batch fire code $59 to tune it. I saw the difference in flow on the n/a 383 i had, so boost I wasnt sure what would happen.
Just monitor each cylinder by checking plugs i guess and see what happens.
Old Dec 31, 2009 | 11:59 AM
jonarotz's Avatar
Car: 91 Z28
Re: Help me decide
Yes I can offset each injector through the Gen 7 so I guess I could do that. It is running in sequential mode as well.
Orr how do you like your single plane?
Does anyone know how much hp the HSR will support? I would venture to guess quite a bit.
Old Dec 31, 2009 | 02:17 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
Re: Help me decide
pardon the hijacking but whats the make and color code for the paint on your car?
Old Dec 31, 2009 | 02:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Help me decide
Love the single plane with the elbow, i kinda like the look. So far it drives very smoothly and seems to be working well with my setup. I dont have anything else to compare it to however, so thats as far as I can describe my single plane experience
However I like the HSR look even more. Kinda wish i would have tried it. I dont think you will have a limit of power with the HSR, as it flows around 265-275 cfm per runner, which rivals alot of the single planes.
In fact, a recent post by 1989GTATransAm shows how different single plane runners can be in flow. Some runners show about 40cfm difference!! Makes me sick to the point I want to send mine off to porting to even things up. Matter of fact I may do this sometime soon while I upgrade a bunch of other things. My ultimate goal however is to end up with a custom sheet metal intake with front mount throttlebody. It will have taper so the rear cylinders will be fed an appropriate amount of air compared to the front.
HSR i dont see much deviation between runners as they are about the same. There are 4 runners that are straight shot to the head port, and 4 runners that have a slight curve in them. Those 4 will be the lower flowing ports but with mild cleaning up with the grinder, you can easily open up the choke point to closer match the cross sectional area of the other runners. I did this with my HSR, using a wrench as a "feeler" gauge to check width at various points.
Single plane just makes working on the car abit easier. Easy acess to bolts and distributor as well as vacuum ports. Get a custom intake elbow made with as many ports as you need to customize your setup. Great for turbo builds which need extra reference points
Old Dec 31, 2009 | 02:50 PM
jonarotz's Avatar
Car: 91 Z28
Re: Help me decide
No problem.
It's the factory color ultra blue metallic, I can't recall the code off the top of my head but I will try to find it for you.
Old Jan 3, 2010 | 11:00 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
Re: Help me decide
No problem.
Thanks man...for some reson that color isn't in my chip book, but i was looking a 93 blue metallic
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
