Do you need to file fit rings @ 5psi
Old Jan 13, 2010 | 09:43 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I finally got a shortblock to replace my 350, its 385ci and with my 64cc afr's itll be 10.4:1. The paxton will make 5psi max (probally 3 but better safe than sorry) on this setup. the rings are file fit right now for nitrous but I have to pull the rotating assembly out and was thinking about new moly rings. Im scared to file fit myself as Ive heard theres more chance to ruin them than get it right. The block only has 6k miles since rebuild so maybe I can reuse the old rings. Or should I just order a set from summit and put them in? What should I do in your opinion?
Old Jan 13, 2010 | 09:49 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Do you need to file fit rings @ 5psi
If it was made for nitrous i'd rerun those rings. Dont need anything special for 5psi boost. File fitting isnt too bad tho if you decide to change them out anyway. Just becareful with the rings so you dont break them when putting them into the bore and get them as level as possible when checking gaps
tom1985
Apr 19, 2016 07:55 AM
89fast5oh
Sep 27, 2015 09:04 PM
RED85TPI
Brakes
Aug 31, 2015 10:29 AM
Omega
Aug 10, 2015 10:24 PM
