just for show. and fun 2 prochargers..
Old Jan 16, 2010 | 03:00 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Hi Guys
ok what do you think about adding not just 1 procharger. but 2
i have so much room on the pasnger side of the eng.. could fit a 2nd procharger.. will have to work out the Mt.. but it should not be a prob..
say 2 of them making 8 to 10 psi ea..
talked to the Guys at procharger they have done it before..
i would be running them into 2 smaller air to air coolers before going into a Y and the TB..
just want to do somthing Diff ya know..
anybody on the site done that yet?
Old Jan 16, 2010 | 03:20 PM
Stephen's Avatar
Car: 87 GTA
Re: just for show. and fun 2 prochargers..
Twin superchargers have been (not on this site that i know of, just saying)....Even seen a twins supercharged AND twin turbocharger car. How in the world that was accomplished and tuned in EFI, I dunno. I just know it i possible to be done.
Old Jan 16, 2010 | 03:28 PM
yes i know it's been done...it's nothing new.. just somthing diff for a 3rd gen with a procharger set up.. tuning should not be a prob at all!
just getting them to bolt up is the Fun part.. they are just air pumps..
would like to get one built for the right side.. so every thing is revs..
but if not.. i can just make the intake tube sweep to even it out.. looks wise.. has the intake will still have the fogger NOS set up on it.
Twin Super Chargers
EFI
NOS Fogger (DE TUNING down to like 100HP hit..or less)
if this works.. ill Back half the car nexed year..LOL
Old Jan 17, 2010 | 02:06 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I have a friend who had twin supercharger on his thirdgen, I posted some pictures of it.
https://www.thirdgen.org/forums/powe...pi-inside.html
Old Jan 17, 2010 | 04:05 AM
Verry Nice.
the one ill be doing will be 2 off the shelf prochargers
going into a air to air cooler.. then to the TPI TB.
im going to try not going to go over 15 to 18 PSI.
the car has been into the 10's without super chargers before. see what i can get out of it.. with them and 44 cid more.
Old Jan 17, 2010 | 09:35 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Definitely would look awesome.
Why not run a dual inlet single outlet intercooler. It would simplify some of the hose routing.
Old Jan 17, 2010 | 09:43 AM
just before my last post..thats what we worked out. with the room up front..
was thinking of 2 coolers (have them) in hand..but not going to use them.
this all started with all the room i have on the pasgr side of the eng.. theres nothing on that side.. it's wide open..
the pick up (intake air will be from the cowl) running down on both sides into the chargers.. then into the air cooler. out from the top middle of the cooler into the TB.. working On the airdam in front might move it forward 4"inch.. looking at if 1 belt will work.. should.. have lots to work with.
Old Jan 17, 2010 | 09:58 PM
1 belt would probably be the easiest. to run 2 you would have offset the head units mounting, plus that would be that much more added strain on the crankshaft.
Old Jan 17, 2010 | 10:03 PM
Stephen's Avatar
Car: 87 GTA
Not much different than the millions of cars with multi-belt systems, before the serpentine belt was designed in the late 80s.
Old Jan 17, 2010 | 11:24 PM
the set up is only as hard as making the braket to hold the Chargers.
added strain on the crankshaft. there will be None.
all of the Bottom end is After market even the Block..
and at 6 to 8 PSI for Ea charger.. thats nothing for a all forged sbc.
this thing will live its life under 6000rpm
and only see that from time to time..
Old Jan 18, 2010 | 08:08 AM
Pocket's Avatar
Car: 91 Trans Am
Aligning the blower brackets is a major undertaking. If your angle is off, even slightly you will eat belts or throw them quickly
Dont count snout strain out for the crank pulley. Even BBC crank snouts are not indestructible
Also, a single FMIC would be more efficient than two smaller units
Im using this
http://www.cxracing.com/mm5/merchant...gory_Code=INCO
But this could also work with a 3rd gen
The 2-to-1 feature cuts out the often problematic Y before the MAF/TB
Old Jan 18, 2010 | 09:55 AM
Running 1 belt for 2 units, I agree there really wouldn't be much added strain on the crank comparted to running a single unit. If you run a 2 belt setup, there would be more strain. You adding another drive pulley further away from the front support bearing, greater leverage on the crank snout.
Old Jan 18, 2010 | 10:45 AM
the 2nd unit is going on the side with nothing on it..
at one time that side had the Air pump and AC on it.. now it's just open.
going to take that open space and fill it with the 2nd procharger.
when i get into the brakets OR Braket could just make one.
but yes Aligning the blower brackets or Bracket will be the first step.
after i get it layed out..
have use of CNC and water jet.. Making one is No prob.
thanks for the link.. saw that one other time and could not remember.
Old Jan 18, 2010 | 11:04 AM
Great use of that open space IMO!
Old Feb 6, 2010 | 03:02 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
One question...Why?
Old Feb 9, 2010 | 02:17 PM
sailbrd's Avatar
Originally Posted by LilJayV10
One question...Why?
I am sure the only answer is ... why not
Old Feb 9, 2010 | 02:20 PM
LilJayV10's Avatar
Engine: 406 Roller
Hehe. That cracked me up.
Old Feb 9, 2010 | 03:34 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Why only 2 when 3 would fit? You could put 2 prochargers and 1 roots in the center.
Old Feb 9, 2010 | 03:42 PM
Stephen's Avatar
Car: 87 GTA
Why stop at just 3? Why not 1 turbo per cylinder, for 8 turbos? :lol
The Inciner8or
Old Feb 9, 2010 | 03:53 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Originally Posted by Stephen
Why not at 3? Why not 1 turbo per cylinder, for 8 turbos? :lol
The Inciner8or
I thought he wanted to use superchargers.
Yeah, he could fill the trunk with turbos and nitrous bottles too.
grngryoutmyway
Oct 18, 2016 05:48 PM
no green
Mar 3, 2016 05:19 PM
Quzyle
Oct 15, 2015 03:35 PM
92projectcamaro
Sep 29, 2015 07:07 PM
