Intake Choices
Old Feb 1, 2010 | 12:17 AM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
Intake Choices
What is a good intake for a low PSI twin turbo carb set up? I'm not looking for huge power, I would prefer good street-drive-ability.
I'm probably looking at 8-10 PSI setup, maybe hit the track once or twice, but this will basically be a street car, 355 SBC, 3.42 gears and a 6 speed.
Should I go single plane or dual plane? Air Gap style?
Old Feb 1, 2010 | 09:01 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: Intake Choices
first off, beautiful car! Im doing the same but red/black.
I would go with a vic jr, thats what I will be running on my street/strip 15-20psi car. Plan on running 9's. It will still be very streetable and being 6 speed im sure you rev over 6000 so it will help on top end.
A few of my buddys use them on there LS cars and like them other then they are N/A and have an elbow which is killing the power.
Im gonna go with the Victor E and have a fast 4bb throttle body and extreme velocity o-ring carb hat.
Jay
Old Feb 1, 2010 | 09:39 AM
TG Goose's Avatar
Engine: 355 SD TPI
Re: Intake Choices
This car probably wont really see anything over 6000rpm, it will be driven conservativley.
Old Feb 2, 2010 | 08:16 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Intake Choices
You want a single plane for better cylinder distribution under boost. When I had a blowthru carb, I used the torker II, b/c I had the stock hood and it was one of the shortest intakes. With your cowl hood, you probably could find something better.
Old Feb 2, 2010 | 09:03 AM
Jay_rich's Avatar
Car: 1987 Z28
Re: Intake Choices
Performer RPM air gap may also be a good choice, my dad likes his, his motor makes 470/470 N/A with it.
Jay
Old Feb 2, 2010 | 02:39 PM
TG Goose's Avatar
Engine: 355 SD TPI
Re: Intake Choices
Well from some research on the trusty internet it looks like the Victor is the intake of choice as it will allow a better flow of fuel/air for boosted applications.
Old Feb 3, 2010 | 12:33 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Re: Intake Choices
Single plane is the only way to go on a boosted application. There are several brands that will work for you. ie. Brodix,Dart, Sniper, Edelbrock.
Old Feb 4, 2010 | 10:39 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: Intake Choices
i swapped out my dual plane rpm air gap for a single plain victor jr for better air distribution.
Bubbajones_ya
Jul 6, 2024 08:32 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
ericjon262
Sep 11, 2015 06:07 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
