trans am procharger guys step in
Old Feb 16, 2010 | 12:12 AM
community's Avatar
Car: 87 trans am clone
Engine: tbi 350 with corvette heads
Transmission: t56
Axle/Gears: 4.11
so for the trans ams i know when you add a procharger the first thing to go is the washer bottle for the windsheild well i have made an aluminum washer bottle that still uses the factory cap if anyone is interested ill figure out a price and let you guys know but first i would like to here from you if you would want something like this
its new resting place will be on the passenger side and it sits under the intake pipe and in front of the evap canister
ill get pics tommorrow and post them out of the car then this weekend ill put it in and then take pics of that
Old Feb 16, 2010 | 09:19 PM
community's Avatar
Transmission: t56
Axle/Gears: 4.11
Re: trans am procharger guys step in
http://
here is what it looks like
Old Feb 16, 2010 | 09:20 PM
community's Avatar
Transmission: t56
Axle/Gears: 4.11
http://s880.photobucket.com/albums/ac6/alexhamm/?action=view&current=DSC00212.jpg][/URL]
Old Feb 16, 2010 | 09:22 PM
community's Avatar
Transmission: t56
Axle/Gears: 4.11
sorry trying to figure this crap out
Old Feb 17, 2010 | 05:59 PM
Twin_Turbo's Avatar
Nice, I may be interested. How does it bolt down? Looks like it might work on my Camaro too. Do you have pics of it installed?
Old Feb 17, 2010 | 07:16 PM
community's Avatar
Transmission: t56
Axle/Gears: 4.11
its still kinda in r&d right now i may take one or two of the tabs off because its a tight fit and i just threw it in the car last night and didnt bolt it down yet i need time to play with it to get it just right last night i realized i need a check valve in the hose because it drains back and wont work unless i suck fluid to the wipers so im still playing with it but eventually ill have a radiator overflow that looks like it and a radiator support and possibly an a/c delete box but when i get it mounted and done ill take a pic for you
Old Feb 17, 2010 | 07:21 PM
Twin_Turbo's Avatar
Won't matter if it's a direct bolt on, not a problem to drill a hole and a check valve, those small plastic things are cheap and easy to get. I like that it's aluminum and would go well with a fabricated coolant reservoir like the canton piece. If you are selling, how much? Would go perf. w/ my custom rad mount & fan setup and I'll eventually get a canton reservoir for it too.
Jorlain
Aug 24, 2022 05:11 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Street Lethal
Aug 14, 2015 08:25 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Leggman1
Aug 6, 2015 04:15 AM
