msd
Old Mar 9, 2010 | 08:26 PM
blklblsk8r16's Avatar
msd
this prolly isnt the right section but i figured most n2o guys should know a little something about msd. my camaro is carburated and i just hooked up my msd 6al box and now my lights (headlights, dome lights, dashlights) flash. the motor is basically stock. no forced induction
Old Mar 10, 2010 | 03:46 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: msd
where did you connect the power and ground for the box?
Old Mar 10, 2010 | 04:24 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: msd
You are wired in wrong in a big way! Dis connect the power wire and grnd wire and start over!
Old Mar 10, 2010 | 10:24 AM
Re: msd
i had a print out from msd that i followed when hooking this up. i ran the power and ground both to the battery, then the rest of the wires are run to the distributor. and i have the one grond wire coming out of the distributorand grounding out on the motor. do you thik the ground on the motor should go on the body? or maybe its just a bad ground
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
