Bi-turbo headers
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Bi-turbo headers
hi
are these http://cgi.ebay.com/ebaymotors/Chevy...item3ef9e15e48
any good ? will they fit and good quality ? i need to buy just headers and lloking for good quality products, if these are junk what should i get ?
best regards
best regards
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
Re: Bi-turbo headers
Same crap as SSAutoChrome, you can search about them.
Basically those headers will require more work to make reliable ten they are worth.
Take a look at these manifolds:
http://cgi.ebay.com/ebaymotors/SBC-C...Q5fAccessories
They dont look as pretty but they will be alot more reliable and they will probably exceed your needs.
They are Gale Banks Sidewinder clones, the Gale Banks kits make over 1000hp with intercooler.
i don't care on looks, i just need some thing that works and will fit with no problem to heads
best regards
best regards
Car: 92 Z28
Engine: Boosted LSX
search the boards for twin turbo ebay headers. a few of us bought and test fitted them. With a little work they would be fine. (mount the turbos in the battery trays with extensions/adapters) brace the turbos/support will help alot also.
A few guys on turboforums are using the ebay headers and running in the 9's etc... (NOT THE EBAY TURBOS just the headers)
They are "decent" for the $$$. if your on a budget.
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
there not that bad actally.. yea all the littel things help. but they do work well for the price. i would just re tig all the welds and more support
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yeah i'd go over the welds to make sure they are sound welds. If they all check out they could work. You could however easily make a set yourself using header materials.
Stainless works sells headers too, and a guy on turbo forums makes sbc headers that should fit. 900 bucks or so for the stainless works ones and about 650 for the turboforum guys. Not exactly budget but very good quality.
Car: 89 Iroc-z
Transmission: TH400
redformula88
Oct 14, 2015 06:08 PM
