Power Adding
Old May 20, 2010 | 05:34 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Power Adding
I am trying to add horsepower to my car but am on a tight budget ($1000). What can i do to add more? It is the origional 5.7 350. I also I am looking for things that I can remove easily and put the stock part back on when I decide to sell it so it can be all origional.
Old May 20, 2010 | 05:45 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Power Adding
For a 1k budget you could do full exhaust and a TB then port your own tpi.
For a true power adder you can't do a roots or centri blower for under 1k, let alone a turbo. A $1000 will get you a nice nitrous kit with all the accessories, and you can un do it all back to stock with ease. Search around you'll make the right choice that fits what you want
Old Aug 12, 2010 | 10:07 PM
Re: Power Adding
What is the best exhaust system I can get like what are the best headers? And by best exhaust and headers Im looking for power more than anything not so much sound. Also how about performance chips? Are they as easy as they sound to install and do they actually put out as much power as they say? If so which is the best to get? I am also looking at getting bigger injectors what size should I get and how much do they cost?
Old Aug 16, 2010 | 08:10 PM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
Re: Power Adding
For under a grand I would say nitrous also. I don't think you can get any good engine mods going on for that little especially if you want to go back to stock easily.
Doing injectors is kind of pointless unless you are going to increase airflow in and out. You don't need more fuel if you don't have more air. IE big mouth runners($339) and baseplate($409), good aftermarket 52 mm throttle body($250-350), airbox mods(free), Long tube headers($200) and full exhaust system.
Getting a chip for your car usually does little to nothing for you unless it is tuned by an expert for your exact setup. And it will take 2 or three to get it right. There's not much point to a one size fits all chip seeing as that is what the car comes with.
The cheapest way to get quicker is rear end gears, nitrous, good tires, and a shift kit. There are very few states left that allow you to run nitrous on the street however. For most folks who only drag race at the track this isn't a problem.
Old Aug 16, 2010 | 08:23 PM
Re: Power Adding
So the ram air system that already comes on my car not provide enough air? What rearend gears do you reccomend 4:10s?
Old Aug 17, 2010 | 05:41 PM
Car: 1992 Camaro RS
Transmission: WC T5
Re: Power Adding
The layout of the airbox on the camaros isnt a ram setup. It pulls air from the area behind the fascia. I cut the bottom of the air box out below the filters to remove the baffolding they put in there to cut down on intake noise. Its a common mod. Some folks buy the kit and rig it up so that the air filter box pulls air from the grille. That one is ram air.
Is this thing a daily driver?
Old Aug 17, 2010 | 05:45 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: Power Adding
Go no higher then 3.42/3.45 gears...
Toss some drag radials on the stock rims, and buy an NX nitrous kit...
jet it to 150, and have fun..
theres obviously more to it then that, but not much, if nitrous is a route you may wanna take, post that, and ill go into more detail.
Old Aug 17, 2010 | 05:57 PM
Car: 1992 Camaro RS
Transmission: WC T5
Re: Power Adding
4.10's are getting into the extreme range for a street car.
Old Aug 17, 2010 | 06:52 PM
Re: Power Adding
yeah its a daily driver.
Old Sep 7, 2010 | 09:02 PM
Re: Power Adding
Okay how about this, what is the best supercharger/turbo I can buy for the money. I dont want one of those top of engine superchargers but one of those ones that mounts off to the side like a turbo system.
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
sailtexas186548
Aug 24, 2015 10:11 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
