Procharger FMU and a Fuel regulator
Old Jul 16, 2010 | 08:01 AM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Transmission: TH 700R4 or TH 7004R
Axle/Gears: Moser 9" 370:1
What's the diff?
Old Jul 16, 2010 | 10:54 AM
KS91Z28's Avatar
Re: Procharger FMU and a Fuel regulator
Your fuel regulator increases fuel pressure on a 1:1 ratio. ProCharger's FMU increases fuel pressure at a far greater ratio that's adjustable.
Old Jul 18, 2010 | 03:31 PM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
I should have said a boost referenced adjustable regulator. Thanks
Old Jul 18, 2010 | 04:04 PM
Twin_Turbo's Avatar
Yes, that's what a boost ref. regulator does, increase 1:1
Imagine you are running 43psi fuel pressure @ atmospheric, if you are at 10 psi boost for instance, that would leave you with an effective f.pr. of 33. This is also the reason why a vac. referenced regulator pulls down the pressure, to keep the absolute effective f.pr. more consistent.
For boost enrichment the FMU increases the pressure at a ratio greater than 1:1
Old Jul 18, 2010 | 08:38 PM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Thank you very much.
Old Jul 20, 2010 | 05:25 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
I thought you had to use the FMU with an fuel injected set-up and were good using a boost referenced press. reg. with a blow-thru carb set-up. Am i wrong here?
Old Jul 20, 2010 | 09:36 PM
Kendol's Avatar
Yes, that is incorrect. An FMU is only used for those applications in which the engine will need more fuel and the user doesn't want to use larger fuel injectors. Basically, they are band aid fixes for applications that really need larger fuel injectors. I am not saying that they don't work, just that they are used as a lazy way to cure insufficient fueling issues.
In any boosted application (i.e. turbo or supercharger) you have to boost reference your fuel pressure regulator. As Twin-turbo pointed out, if you pressurize your intake 20 psi and you run a fixed WOT fuel pressure of 45 psi, your engine will only see an effective fuel pressure of 25psi. The whole point of boost referencing a FPR is that it maintains the same effective fuel pressure regardless of the boost you are running (assuming it is 1:1).
This applies whether you are using a carb setup or an FI setup. It's all about maintaining the same effective fuel pressure under boost/vacuum situations.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
