turboing
Old Sep 15, 2010 | 12:30 AM
boosting28psi's Avatar
turboing
where is the best place for a kit?
or what is the best way for a home built kit....
asking before i jump into it
Old Sep 15, 2010 | 12:40 AM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Re: turboing
No kits available..
Best way is relative... if you mean easiest way, single is easiest because you can use the stock driver side manifold and mount the turbo on the passenger side. Oil drainback can go into the fuel pump blockoff plate in most cases. You can then tie a 3" downpipe inside your catback following stock routing from the starter back. I hope you have a welder!
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
