Another turbo build...
Old Nov 10, 2010 | 08:38 PM
hotshift13's Avatar
Car: 89 Trans Am
Engine: 305 alive
Transmission: slugomatic
Hello everyone, Ive been a member for years but I really haven't posted at all, until now. I want to do a twin-turbo set up on my car, but I want to use one of these ebay set ups. Id like to document everything and make a sticky out of this post on how to do this swap. I see a few posts started about my car, but they seem to die-out after a while. All the stickys are 9 years old and none of them relate to a ebay kit.
First off I have an 89 Trans-am, 305, tbi, 700r trans, the cars pretty much bone stock, except a repaint last year by me, and some ws6 wheels off a 2000 TA. The cars got 160isk on the clock, typical blue cloud on start up, just stock and slow.
Now my goal for the car is to use the stock 305. use an ebay turbo kit, or make everything else, I have some fab skills, and I turboed My Datsun 280z. The car will be a street car, maybe go to the track once in a while. So I want it to look stock, except when I open the hood.
My HP goals are in the 400-425 range, I have a $2000.00-ish budget. I'm still in the research phase now, and deciding if I should buy a all inclusive kit, or buy only what I need, because some kits come with stuff I wont need like an electric fan ect.... I plan to take nice pics of my project so other people can follow in my foot steps.
What do you guys think, wanna add to this, and help me out on my way?
Old Nov 10, 2010 | 08:44 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Another turbo build...
are you going to use the tbi? seems like the air would deflect alot. I have a Dastun Z also....cool!
Old Nov 10, 2010 | 08:46 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
your probably better off peicing it together that way you know what you have and then can move onto installing it.also you will probably get better quality products if you peice it together
i think i have less than 2k into my build and its a single turbo setup
Old Nov 10, 2010 | 09:05 PM
hotshift13's Avatar
Car: 89 Trans Am
Engine: 305 alive
I plan to use the stock tbi unit....if possible. I want to keep this pretty simple and not hack up the car, too much. My wife has owned this car for almost 19 years, so it's not going anywhere. Im looking at the kits now and im seeing a lot of stuff i don't need, but some stuff I didn't think about, like an oil cooler....
Old Nov 10, 2010 | 09:38 PM
i would think that the tbi unit itself will be a restriction........imo.......not to mention i dont see it having a good sealing area cor the carb hat due to the wiriing harness for the tbi injectors.....
Old Nov 10, 2010 | 09:57 PM
the TBI wont let you reach the boost levels you need to get the power you want. i would swap the intake with and go carb. even with a carb you loose 3-4psi through it.
Old Nov 10, 2010 | 10:36 PM
hotshift13's Avatar
Car: 89 Trans Am
Engine: 305 alive
http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories
Old Nov 10, 2010 | 10:39 PM
joker0907's Avatar
Car: 1991 camaro rs, 2001 buick century
Engine: 305, 3.1
or u could go to the with a tpi setup would prob go over ur budget with getting a fuel system setup and will take more work in tuning. i wouldnt mind seeing it though haha. those are t3/t4 hybrids that should do pretty decent on a 305.
Old Nov 10, 2010 | 10:46 PM
hotshift13's Avatar
Car: 89 Trans Am
Engine: 305 alive
http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories Just throwing this out there looking for opinions. I like the header design, keeps the turbo low.. easier for plumbing? just looks good to me, but a lot of other stuff I wouldnt need tho...
The tbi question... I really don't want to go carbed, change fuel pump, ses on in the dash, lock up converter wont work, lots of things, and driving up the cost.
Old Nov 10, 2010 | 10:49 PM
hotshift13's Avatar
Car: 89 Trans Am
Engine: 305 alive
http://cgi.ebay.com/ebaymotors/86-92...5fAccessoriesI really like the intercooler in this kit, and not a bunch of extra garbage. the price is not too bad either...
Old Nov 11, 2010 | 08:47 AM
joker0907's Avatar
Engine: 305, 3.1
i dont like how the last one says it comes with 2 turbo.... id rather have the t3/t4s myself but i like that kit too
Old Nov 12, 2010 | 06:33 PM
hotshift13's Avatar
Car: 89 Trans Am
Engine: 305 alive
Still looking myself, anybody else have anything to add?
Old Nov 15, 2010 | 09:32 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I would stick with doing your own kit. If you bought a kit, like those ebay ones, you may or may not get full use out of it. Probably alot of parts you may not need.
I would buy piping as you need it. That will keep excess pipe costs down. I bought bends as I needed them, 4-5 at a time and I still had a bunchof straight pieces left over since I really just needed bends. I didnt have any extra tho
Since you can fab, i'd build my own set of manifolds. Just order a flange for the heads, and go from there. Could start with a stubout kit from summit but they are 175 bucks or so if using Hooker headers. I used that on my build. i have probably 400-500 total in my twin manifolds including 120 bucks to finish tig/mig weld them from my buddy's shop. I just tacked them all together. It was rather easy to make although I made them sit up abit higher than i wanted.
t3/t4's will be awesome for 400hp. I think the bigger ones you find on ebay, the stage 3's or whatever have around 50mm compressors. Should be plenty for a mild 305. That will keep cost down.
Could easily get away with 2.5" downpipes so that will make it easy to route them in the car compared to my 3" pipes on my setup.
I'd convert to TPI if you can...but I dont know much about TBI and if they can be blown thru. If they can, then go for it. Can EBL handle boost?
TPI you can convert to 730 ecm and run code $59. Cheap and works fine. Just need to get a base map to work with. I started by copying the base VE table from a 350 8D code and tweaked the egr "fuel injector constant" in code $59 til it started and ran on its own, then had a lot of tweaking to do from there. Still not done but its very driveable at the moment.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
